Old 12-07-2010, 01:40 PM   #1
1986 25' Sovereign
Greenwood , South Carolina
Winterizing/Oil in the gas line/misc talk
Merry Christmas one & all! Hope this message finds everyone well.
Have an 86 Soverign that we are attempting to winterize. Have put anti-freeze in, but water pump does not seem to be pumping like it should & did this summer. Am thinking the pump might bad. When we turn pump on, you can hear it running, but it is not pumping like it is supposed to.
Another item, we are thinking there might be oil in the gas line, any suggestions for blowing the lines out?
If there is anti-freeze sitting in the lines, is this a bad thing? How can we flush them out?
Any help or suggestions or ideas please let me know.
Thank you
Carole
Success101 is offline   Reply With Quote
Old 12-07-2010, 03:01 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Carole,
Where did you put the antifreeze? In the fresh water tank? If yes, then you probably don't have enough in the tank for the pump to pick it up and pump through the system.
Did you look for a winterizing tube on the pump, or located really close to the pump? It's purpose is to stick the open en dof the tube into the jug of antifreeze and pump directly from the jug so you don't have to put the antifreeze in your tank. If installed, they are located on the input side of the pump, and there should be two valves. One goes to this tube, and the other one in in the line from the fresh water tank. To use the tube, close the valve from the frash water tank and open the valve that goes to the tube. Then run the pump to fill up the water lines with antifreeze. You'll also want to look for a winterizing bypass set of vavle by the water heater so you're not pumping 6 or 10 gallons of antifreeze into the heater tank.
This is the short version of directions for winterizing. There are many threads on this topic as well. This one is pretty good I think: http://www.airforums.com/forums/f459...eam-70171.html
On to your other question. Why do you think there's oil in the gas lines? And you mean the propane lines, right?
Chris
Old 12-09-2010, 07:20 AM   #3
1986 25' Sovereign
Thank you Chris!
I am being told that putting the hose into the gallon of antifreeze & it would not even pump out of the bottle of antifreeze.
Yes, I meant propane lines...sorry!
Thank you
Carole
Old 12-09-2010, 09:19 AM   #4
r carl's Avatar
Lin , Ne
Originally Posted by Success101 View Post
Another item, we are thinking there might be oil in the propane line, any suggestions for blowing the lines out?
Thank you
Carole
I got to ask, why would there be oil in the propane line?
Old 12-09-2010, 09:26 AM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Carole, if you are referring to a hose at the water pump (not a regular line that you disconnected), then there is likely a valve where the hose connects to the water pump that you need to turn. This valve allows the winterizing hose to work.
Good luck - Pat.
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-09-2010, 10:30 AM   #6
Minno's Avatar
1972 31' Sovereign
There should be 2 valves. Close the one that comes from the fresh water tank, and open the one that goes to the tube you stick in the bottle.
Chris
Old 12-09-2010, 11:48 AM   #7
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Trace amounts of oily residue in propane lines are not an issue - however, if there is enough to pool it could represent a problem. Is it pooling?
TX-16
Dave Park is offline   Reply With Quote
Old 12-13-2010, 12:48 PM   #8
1986 25' Sovereign
This is an unknown problem for us. We bought the camper used & the oil was found when cutting a crimped line. We were wondering if this was a common problem?
Thank you to everyone!
Old 12-13-2010, 01:02 PM   #9
Dave Park's Avatar
2005 22' Safari
Propane is a petroleum by-product (or natural gas processing, which is not relevant here) - it is a specific fraction and no fraction is 100% pure. Over time, a very small amount of the heavier fractions will settle out and make a light, oily residue. Over many years, this residue can become quite thick, even tar-like. It is non-hazardous.
TX-16
Old 12-13-2010, 01:13 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Oil in the propane line is not uncommon, I think is is part of the process of putting in the smelly stuff.
Getting to your pump problem. You can use a bottle of RV antifreeze to winterize, it will take a couple of gallons or so. If you have drained your fresh water tank and the pump has sucked in air. You need to reestablish the prime of the pump. Take piece of hose long enough to reach the bottom of the bottle and connect it to the intake of the pump, make sure the hose is full of anti freeze. Then disconnect the discharge hose from the pump. Run the pump just long enough to see if you get a good flow out the discharge. If you do get a good flow then reconnect the discharge hose to the pump and open a faucet and turn the pump on. If it works and you have used all of the anti freeze in the bottle you may have to reprime the pump again. To prevent this just shut the pump off before the antifreeze level is too low and add more antifreeze to the bottle you are pumping from.
Oil Cooler Line gunner Mechanics Corner - Engines, Transmission & More... 13 08-30-2010 04:05 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Oil in the propane line and a connecting hose dbensen LP Gas, Piping, Tanks & Regulators 2 10-20-2005 07:50 AM
Oil in propane line Deputych LP Gas, Piping, Tanks & Regulators 1 10-18-2004 06:26 AM
HELP Emergency oil line busted! Astrodokk Airstream Motorhome Forums 8 10-30-2003 07:01 AM
