Old 12-10-2004, 12:23 AM   #29
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up By all means
Originally Posted by wheel interested
Should I be pushing the button on the moen one touch to get antifreeze through the filter? I didn't. Should we remove it? It's been heated thus far and antifreeze pumped through, but wondering in case we turn the heat off. Is there a problem to leave shore power on all the time with the batteries?
Thanks.
P.S. We used the mint antifreeze, it took forever for our water not to taste like mint, kind of threw off the taste of my hot tea.
Carol,
Greetings~!
By all means remove your filter from the Moen fixture..
I'd just store it till Spring, risen it out and then re-install it~
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-10-2004, 07:27 AM   #30
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re-installilng a previously used water filter
Originally Posted by 53FlyingCloud
Carol,
Greetings~!
53FC
I pulled mine out also. I am curious though since this is my first trailer with an inbuilt filter. If I remember correctly, the "brains" of the Moen fixture consider that when a filter is installed, the use cycle measurement starts over...meaning it considers that you have installed a new filter. I guess this means by re-installing the old, you could use the filter beyond its standard life. To me this would mean that the filtering function, other than particulates, is non functional.
Would there be any other concerns?
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-10-2004, 07:31 AM   #31
jcanavera's Avatar
Fenton , Missouri
Images: 143
I've always been curious about this since up until I bought the Classic, I've always used the fresh water tank method as the means to inject RV anti-freeze into my trailers. I always flushed things throughly each spring and never had any tainting of the water. I'm beginning to believe my taste buds are dead or maybe folks just aren't doing a good enough flush of their systems.
Jack
Jack Canavera
STL Mo.
AIR #56
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
Winterizing in Alberta altastars Winterizing, Storage, Carports & Covers 13 10-22-2004 05:17 PM
winterizing question Stefrobrts Winterizing, Storage, Carports & Covers 11 11-03-2003 04:11 PM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
