Old 10-06-2008, 07:46 PM   #1
2004 25' Safari
Fair Oaks , California
winterizing in the sacramento area of Calif.
Suggestions on winterizing in the sacramento area of calif.
1911dan is offline   Reply With Quote
Old 10-06-2008, 07:54 PM   #2
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
no winterizing is needed here in sunny california.
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 10-06-2008, 07:57 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
It will likely never approach freezing at floor level even if you see 20 degrees outside temps early in the morning. Go up to altitude? You'll need full winterizing. http://www.airforums.com/forums/f458/
Member Leipper has taken inside temps near the floor in cold conditions and these were his conclusions.
But members with copper pipes should be very aware -- they could experience permanent damage & sweated joint breaks very early in any freezing encounter.
5 meter Langford Nahanni
Old 10-06-2008, 09:31 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
When we bought our '65 Caravel in 2001, the plastic flow meter in the demand water heater had a crack in it and leaked water. The PO lived in Placer county, and the trailer spent time in Lincoln, just north of Sacramento.
We have been wintering in the south, however, if we were to spend any of those cold Delta winter nights in Walnut Grove, just south of Sacramento, I would certainly spend the few minutes it takes to drain the water system.
2024-T3 aluminum, Sacramento walter1 Ribs, Skins & Rivets 6 02-08-2007 08:50 PM
Folsom- Sacramento Ca Area Boondocker Off Topic Forum 14 08-24-2006 02:40 PM
Best place for service in Sacramento California area newtoAS Commercial Listings 5 05-22-2006 05:05 PM
Sacramento to Salem Oregon cynthia On The Road... 12 09-16-2005 08:42 AM
Any experience with RV'S OF SACRAMENTO guy99 Commercial Listings 0 07-05-2005 11:07 AM
