Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 11-02-2013, 02:39 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Winterizing in Puget Sound
Hello!
This is our first winter with our new Airstream. We'd still like to take the trailer out this winter here in Puget Sound. But if we winterize it, does that mean we can't take it out unless we de-winterize it?
It gets cold here in Puget Sound, but it doesn't always freeze. So I'm wondering what folks here in the Puget Sound area do? Do you winterize? If so, have you already winterize this year?
Thanks in advance!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 11-02-2013, 05:32 PM   #2
dprvashon's Avatar
2015 25' FB Flying Cloud
Vashon , Washington
Images: 11
Ditto the question. We just got our first AS19FC and am wondering what others in the Puget Sound do? Also is it best to run a little electic heater set on low?
I was planning on draining the water tank, the plumbing, and the hot water tank. I was also going to disconnect the batteries. But I can leave it plugged into a 15amp line and charge them periodically. What is best?
If it is like our boat, moisture won't become a problem until spring when we get more temp change then we need to use a dehumidifier, fan or???
Where do you take your AS in the winter around here?
2016 Flying Cloud 25 FB Twin
2014 Ford F150 3.5L V6 Ecoboost w/ max towing pkg
oh, and Cleo the wonderdog
dprvashon is offline   Reply With Quote
Old 11-02-2013, 05:52 PM   #3
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
You Semi-Winterize It
We can still use our Airstreams in the winter.
But what is winter where you are? How cold does it get? Will you be using it continuously, or off and on.
If you are talking about occasional camping with with trailer in storage when you aren't using it, you take one approach (We'll call it Approach 1) if you intend to camp in continuously a different approach is required (Approach 2).
Approach 1:
Winterize
Empty fresh-water holding tank.
Empty the hot-water heater.
Blow out the water lines.
Carry your water as you would if you were tent camping.
Drink from 5 gal water jugs
Flush with a bucket by the toilet
Heat water on the propane stove for sponge baths.
Allow all waste water to drain through holding tanks into sewer.
Approach 2:
Keep 'er heated
Don't winterize
Find the great thread about living on the South Rim of the Grand Canyon all winter.
Your approach (Approach 3?) will be some enlightened combination of 1 and 2 with ingenious solutions and specialized equipment.
Be bold and creative!
Hope this helps.
P.S. I have spent the last two winters in our Airstream...(in Mesa, AZ)
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 11-02-2013, 06:03 PM   #4
Alumaholic's Avatar
Images: 36
Winter Camping in the Grand Canyon
Here's that thread:
http://www.airforums.com/forums/f459...yon-98031.html
Enjoy
Ken L
Old 11-02-2013, 06:09 PM   #5
dprvashon's Avatar
Vashon , Washington
Images: 11
Alumaholic.....
We might get a winter with freezing temps and then again, maybe not. Last year was mild with no snow and it only dipped below. 30 once or twice. But, I have seen winters with weeks of snow and a week at 15 degrees.
I do like your thought, snow birding in our AS to Arizona. Our neighbors go to Baja in their RV but I am not ready for that. I have a client in Tuscon. Maybe somewhere around there?
Approach 3.......go anywhere its not grey
Old 11-02-2013, 06:09 PM   #6
AlumFalcon's Avatar
2012 27' Flying Cloud
Kirkland , Washington
Every winter it gets below freezing at night in your area so you have to do something. Alumaholic sums up your options well. We camp all winter long so we do option 2. We run the propane furnace on a low heat to keep any water in the lines from freezing. We haven't had a problem yet. Kinda a pain to keep refilling the propane but we want our trailer ready to go. If you only plan to camp a couple of time then winterize and dewinterize, it's pretty easy. Or swing by Convington and have them winterize for 50 bucks.
AlumFalcon is offline   Reply With Quote
Old 11-02-2013, 11:20 PM   #7
2017 27' International
Fall City , Washington
Time:
I had the same issues you did with the new FC. We have plans for a few winter trips that will take us to slightly warmer climates, but needing to travel through passes. Otherwise, she'll sit through the toughest of the winter months.
Here's how I am planning. I bought a reasonably portable air compressor to have handy, and rigged up a blowout hose. Drained the hot water tank, keeping the fresh water tank empty, blew out all the lines, and a bit of RV antifreeze in the traps, just in case. But didn't run antifreeze in the water lines.
For the few trips we will take during winter, we will travel dry and use city water when we reach warmer climes. Just before we leave our last camp spot coming home, will run a sewer flush, then drain the black and grey. Once home, will blow out lines again and follow the above regiment.
One thing I did last week was to spend a Saturday putting on paint sealant so I'd just have to hose her off after a trip and do a quick spray on wax.
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 11-03-2013, 12:24 AM   #8
time2play's Avatar
2013 30' Classic
Kent , Washington
Thanks everyone! We'll probably winterize and de-winterize as needed.
I appreciate all your responses. As usual, you've been very helpful.
Yolanda (and Phil)
WBCCI #7878
Old 11-16-2013, 04:31 AM   #9
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
I have a good 12v tire inflator that hooks directly to the battery, can this be used to blow the lines out ?
Thx
Dan
Dan S is offline   Reply With Quote
Old 11-16-2013, 08:33 AM   #10
mapleton , Utah
what you need is a pretty good amount of air flow to blow out the lines , most inflators pump fairly slowly. look at the black friday ads at your local big box store and get a larger air compressor. you will be much happier with the results.
tim
rumrunner is offline   Reply With Quote
Old 11-16-2013, 08:38 AM   #11
Hard to say. You can try it, but my guess is that you may need the air tank capacity, say 4gallons or more. I don't think a standard air tire compressor can properly pressurize the lines.
I use a Makita MAC 2400, which does just great. It has a 4 gallon capacity. If you just plan to use a compressor for this task only, I would probably look into a cheaper Harbor Freight or porter cable unit.
Old 11-16-2013, 09:08 AM   #12
Alumaholic's Avatar
Images: 36
Thx
Dan
You can use a 12 v tire inflation pump, but it is tedious, time consuming, and paradoxically a bit riskier. Best to have a compressor with a tank and a regulator to limit the amount of air pressure you apply to your water lines, joints, fittings, faucets, etc.
The problem with the 12 v pump is you must pressurize, open a faucet, repressurize, open another faucet, over and over... Each time you pressurize you run the risk of over-pressurizing. A moment of inattention compounded by frustration and impatience and you will have damaged a line in some inaccessible spot.
With an air compressor equipped with tank and regulator you can maintain air pressure consistent with water pressure design capacities of your Airstream.
Ken L
Old 11-16-2013, 10:11 AM   #13
2013 25' FB Flying Cloud
Edgewood , New Mexico
Winterize FC
Agree with Alumaholic's approach #1. We live just East of Albuquerque at 7,000ft and always do approach #1 to our 2013 25'FB FC. Previously, we had a 19' Bambi and had no problems winterizing, de-winterizing, and re-winterizing during our winter trips--mostly to South Texas and back.
It does get down to 15 degrees, and even lower sometimes here in the low mountains. I use a 8 gallon air compressor and blow out the lines using ~45 lbs pressure for each of the inside city water supplied faucets and toilet up to 3 times each. Also, I keep the belly drain valves open and all the faucets open when finished. (We do not use the hot water heater, nor the fresh water tank and its pump so they remain dry.) We pour RV antifreeze down the traps and toilet.
High Cloud is offline   Reply With Quote
Old 12-03-2013, 05:42 PM   #14
Jeff
jkinglet's Avatar
2013 Interstate Coach
Seattle , Washington
Images: 37
Travel during the winter -- short trips out of Port Orchard, never winterize, never had a problem. Run this "Little Eva", drain the tanks and run the heat every week or so. Nice to be able to hop in and go without the winterizing fuss. Just hope we don't get a storm like December 31 1968, but not likely. The small dehumidifier fills about every 2 weeks this time of year and works like a charm ($40 Amazon) (20' FC). Jeff
jkinglet is offline   Reply With Quote
Old 01-04-2014, 08:40 PM   #15
Clar7135's Avatar
2005 19' Safari
1 , Washington
New airstreamer here... I erred on the side of caution and drained all the tanks, blew out the lines, and filled with rv antifreeze. It gets pretty cold at night, and at least you don't have to worry about it freezing up.
Clar7135 is offline   Reply With Quote
Old 01-05-2014, 12:00 AM   #16
Living Riveted since 2013
Rocinante's Avatar
2016 Interstate Lounge Ext
Green Cove Springs , Florida
Just around the last week of November / first week of December we had a crazy cold snap in the Puget sound that pretty much froze everything. So if your TT wasn't either winterized or well heated, it was probably gonna need repairs. We don't get a lot of below-freezing temps that last long enough to matter, but those snaps take many by surprise when they come, and that's when the fun begins.
Thus, as a new owner anxious to protect the investment, I opt for choice #1 (winterize and weekend camp in our aluminum tent from time to time until the spring). No water anywhere inside the TT's plumbing until then - and that includes the tanks. I don't want a cold-snap surprise while it's in storage between trips.
Old 01-05-2014, 12:03 PM   #17
time2play's Avatar
2013 30' Classic
Kent , Washington
We winterized right after I started this thread. It was a good decision for us.
Thanks everyone for all your advice. Maybe next year we'll do some winter traveling.
Yolanda (and Phil)
WBCCI #7878
Old 01-05-2014, 01:07 PM   #18
Dan S's Avatar
1975 Argosy 26
I winterized with antifreeze for the first time in Seattle this year as well and glad I did. I previously had a Argosy Minuet and did not winterize and had a leaky water tank. After a couple hundred dollars in repairs I learned my lesson.
I installed a antifreeze intake between the water tank and pump and it makes the process simple and quick.
Old 01-05-2014, 03:30 PM   #19
Rocinante's Avatar
Glad you winterized, and good idea on the antifreeze intake. Maybe we'll add that one day. For now, we'll just have Covington winterize it. Meanwhile, for those playing along at home, we just had another overnight cold snap, down to 27F. The snaps keep coming. We see nothing like the temps you'll find east of us at the same latitude, but it sure gets cold enough to damage pipes and tanks if there's water in them and the trailer isn't heated.
