Old 10-19-2013, 02:25 PM   #1
troutbum
sldflyfish's Avatar
2010 27' FB Flying Cloud
Phoenix , Arizona
Winterizing in Arizona
When " winterizing" in an area where freezing temperatures are not an issue ( Phoenix AZ, for example), is it better to drain the potable water and hot water tanks or leave water in them?
sldflyfish is offline   Reply With Quote
Old 10-19-2013, 02:45 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
If you're using the water (in both instances) frequently, I wouldn't see the need to drain them.
But if they set for a month or so, I would.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 10-19-2013, 02:55 PM   #3
troutbum
sldflyfish's Avatar
Phoenix , Arizona
Thanks. I thought that might be the case, but wasn't sure.
Old 10-19-2013, 05:30 PM   #4
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
When I know I won't be using the Airstream for more than a month, I drain both the fresh-water holding tank and the H2O heater. Here's why.
Water from a municipal source may be chlorinated when it goes in, but chlorine dissipates over time and depending on your water source, some troublesome things can start to happen.
In the H2O heater especially, there is a tendency for some organism to take over producing a strong hydrogen sulfide (rotten egg) smell. Once it takes over, it is very difficult to kill it and get the hot water smelling fresh again. It's much easier to drain the tank.
In the fresh-water holding tank, I am concerned about the odorless, tasteless bacteria that might develop.
When I drain the fresh-water tank, I add 2-3 ounces of sodium hypochlorite (household bleach, unscented) and a couple gallons of water to cover the bottom of the tank.
If you are someone who can't stand chlorine, and only fills your tanks with non-treated water, it's probably even more important to drain.
As a footnote, we just returned to our winter home in Mesa, AZ. I forgot to drain the H2O heater when I summerized last April. The hot water reeked of hydrogen sulfide. Very unpleasant, and it took hours to drain and rinse.
Hope this helps.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 10-19-2013, 09:14 PM   #5
2005 19' Safari
GLENDALE , AZ
We live in Phoenix, AZ; and we don't winterize at all. Freshwater tank is always full, including hot water heater; and gray and black water tanks are empty when our Airstream is parked alongside our house. No water issues, but we use bottled water for drinking and cooking; and only use freshwater tank for dishwashing, bathing and flushing.
We camp frequently in the winter, and our Bambi is always ready to go. We've been doing this since 2005 when our Bambi was purchased new.
Old 10-20-2013, 10:09 AM   #6
troutbum
sldflyfish's Avatar
Phoenix , Arizona
Thanks for all the great advice everyone. I appreciate it.
Old 10-20-2013, 04:31 PM   #7
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
It depends...
Down in the valley (Phoenix, Tempe, Chandler, etc...), We have never winterized. Fall & winter is the camping season here. If I lived or stored the trailer at higher elevations (Flagstaff, Show Low, etc...) where they have real winter I would go for the whole winterize process.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
