Old 12-01-2009, 09:34 AM   #43
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Furnace. Mid 20's might causing freezing problems in the water tanks, and the forecast may be wrong and it could go lower.
Gene
Old 12-01-2009, 09:50 AM   #44
HowieE's Avatar
Princeton , New Jersey
Images: 12
You should be OK. What you have to fear is freezing oven night and remaining below freezing during the day and freezing again the second night. Now if it is in the 30s during the day and going down that night I might get concerned.
The trailer is a large thermal mass and it takes some time to drop the temperature in it.
I have frequently had nights in the 20s and awaken with the supply hose frozen but the trailer systems OK.
2004 Excursion 4x4
Old 12-01-2009, 10:04 AM   #45
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
Originally Posted by By the Bay View Post
I don't have a compressor.
Can I winterize without a compressor (ie, without blowing the lines) ?
Can I drain it all, then use Multiple Gallons of RV Antifreeze? I'd sent it thru the whole system... open faucets, shower, toilet sprayer, etc until they run pink... including hot water heater?
I have never used a compressor for winterizing. I drain the hot water tank, put the system on bypass and run RV antifreeze through the system. I have a 32' trailer and it takes 2 gallons including dumping a cup of RV Antifreeze into each p-trap.
Ben4762 is offline   Reply With Quote
Old 12-01-2009, 11:44 AM   #46
galfoman's Avatar
2002 19' Bambi
Dorchester , Massachusetts
FYI
I just picked up a small air compressor from Home Depot on sale for $99.
It's worth having even if you only use it for winterizing and filing your tires.
Doing mine today because it froze a little last night.
BTW, It's all you will need to to power a finish nailer or pneumatic sanding and grinding tools if you plan to do a restoration.
Check it out.
1 Gallon, 135 PSI Max, Trim Compressor - D55140 at The Home Depot
I saw a Husky one there too that was even smaller and only $69.00. It also included a hose, a brad nailer and a bunch of toys.
Husky 2 Gallon Compressor with 3 Tool Kit - H2G3TK at The Home Depot
galfoman is offline   Reply With Quote
Old 08-26-2010, 08:35 PM   #47
1976 31' Sovereign
Marlette , Michigan
Unhappy need information
Kevin 245
I'm in need of the same information about winterising a 76 Airstream Soverign.
I have misplaced my owners manual and Michigan eats travel trailers for snacks http://www.airforums.com/forums/imag...lies/lol.gifif left un prepaired for winter. my email address is [email]rymndmr1@yahoo.com thanks Raymond.
rymndmr is offline   Reply With Quote
De-winterizing gsgofish Winterizing, Storage, Carports & Covers 0 05-22-2009 08:02 PM
De-winterizing snpotratz Fresh Water Systems 7 03-19-2007 12:48 PM
Fishing line takes out brakes? LI Pets Brakes & Brake Controllers 16 02-28-2007 08:05 AM
Winterizing jacobjames Member Introductions 1 10-13-2006 03:32 PM
