Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 10-06-2009, 03:45 PM   #1
Airstream 65's Avatar
Profile:  1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
Winterizing Compressor Question
I'm thinking of getting one of these two DeWalt air compressors for blowing out the lines in our 65 Overlander and 09 International.
DEWALT D55168 : 1.8 HP Continuous, 200 PSI, 15 Gallon Workshop Compressor
DEWALT D55167 : 1.5 HP Continuous, 200 PSI, 15 Gallon Workshop Compressor
Would either one of these be able to do the job?
Thanks.
Airstream 65 is offline   Reply With Quote
Old 10-06-2009, 04:42 PM   #2
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Yup - either one would work, the smaller one would be just fine. You could get by with an even smaller one if that's all you're buying it for. 4.5 SCFM at 100 PSI is more than enough air flow. You probably only want it set to about 40 PSI for blowing out the lines.
Chris
Old 10-06-2009, 07:48 PM   #3
Winnipeg , Manitoba
Ok, thanks for the input. I'll give one of these a try.
1964 Overlander A/C Compressor question 64Overlander Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-15-2009 03:21 PM
A/C Compressor question PhilMateo Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-19-2006 08:23 AM
Air compressor question... malconium General Repair Forum 6 01-13-2005 07:15 AM
(total newbie question)Compressor/Airbags in a 76 argosy 24? 76Argosy24_Thomas Mechanics Corner - Engines, Transmission & More... 4 11-12-2003 02:08 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 08:01 AM
