Old 09-24-2003, 07:53 AM   #1
1999 25' Safari
Edina , Minnesota
Winterizing-Adding Antifreeze
When I winterize, I drain all water, blow out the lines with compressed air, drain the water heater, close the WH bypass valves etc. and then add RV anti-freeze for an extra margin of protection (gets cold here in MN in January).
My wardrobe is fitted with custom-made drawers and the water pump is not easy to get to unless absolutely necessary, so I add the anti-freeze to the water tank and run the pump as normal to fill the lines, but this method uses a lot of anti-freeze.
So...here is the question:
Has anyone installed/developed/used a method of adding anti-freeze to the lines using the existing pump without needing direct access to the water pump each time?
Thanks for the help.
JC
1999 Safari 25C
2009 Yukon Denali
WBCCI #2369
JaceBeck is offline   Reply With Quote
Old 09-24-2003, 08:26 AM   #2
Gordon Watt's Avatar
My Ever Flo Pump has quick release connections. I have a connector on a piece of hose. I connect it to the pump and draw the anti freeze direct from the container.
It takes less than one and a half gallons this way.
My trailer is stored way up north in Thompson Manitoba. We're talking minus 54 degrees at times. The trailer came through unscathed.
Gordon Watt is offline   Reply With Quote
Old 09-24-2003, 05:26 PM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
jace
go get yourself a 3 foot piece of clear silicone tubing from your hardware store.
size it to fit snugly over the threads of the intake side of your water pump.
turn the pump on and insert the other end of the tubing into a gallon of antifreeze. two or three gallons should do your whole trailer with the water heater by passed.
one inch i.d. hose fits my water pump nicely.
hint: if the hose is a little too tight, heat the end with a lighter until it becomes soft, it will slip right on!
you won't need to put all that antifreeze in your fresh water tank.
john
Old 09-24-2003, 05:33 PM   #4
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
I don't understand why the antifreeze is needed if all the water is blown out of the lines??? No water = Nothing to freeze!
And, I would think, even if a few drops of water are left in the lines here and there, that wouldn't be enough to do any damage.
yukionna is offline   Reply With Quote
Old 09-24-2003, 05:45 PM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
just extra protection
yukionna,
antifreeze is just added protection.
even with blowing the lines out you can never be sure all the water is gone.
it doesn't take more than a couple of drops of water to destroy things like the sprinkler head on the toilet or the vaccum breaker on the shower.
been there done that!
i can walk past my trailer on my way to my truck in january, with my breath freezing in mid air, knowing i won't be buying a whole lotta pex tubing in april!
john
Old 09-24-2003, 06:33 PM   #6
yukionna's Avatar
Massachusetts
Images: 18
If you by-pass your water heater with antifreeze, what keeps the hot water heater from getting damaged?
Old 09-24-2003, 07:13 PM   #7
Images: 59
Antifreeze
How come none of are southern brothers and sisters are joining this thread?
But seriously, folks: I think one of the advantages of pex is that it can expand slightly if water freezes in it. I'M NOT RECOMMENDING YOU TRY THIS. But I think a few drops of water, if it has some airspace to expand into, will not burst pex tubing. I do now that a little water in the bonnet of a gate valve will split it wide open. I would leave any valves half open so that there isn't any water trapped in the bonnet area.
And don't forget to add a little antifreeze to the pump on your pressure washer if you store them in an unheated garage.
Old 09-24-2003, 07:26 PM   #8
Edie's Avatar
Dallas , Texas
Because we know the only real way to "winterize" is to spend the winter in the sun belt.
Seriously, our best traveling weather here in FL is just ahead of us.
Edie
Edie is offline   Reply With Quote
Old 09-24-2003, 07:52 PM   #9
Chas's Avatar
Images: 22
Winterizing already? Are ya'll nuts or what?
I will probably winterize mine the first time for winter around New Years, maybe a few times more after that in-between camping trips. Camping season has just begun for us!!
Chas
Chas is offline   Reply With Quote
Old 09-25-2003, 07:48 AM   #10
B25guy's Avatar
2003 25' Safari
Yakima , Washington
Images: 20
and the traps!
Don't forget to add about a cup of RV anti-freeze to each of your drain traps (shower, lav and kitchen). You'll want to keep those full through the winter so that you don't get some really funky smells in the spring...
B25guy is offline   Reply With Quote
Old 09-25-2003, 08:44 AM   #11
Images: 59
Winterizing
Chas, Edie:
Thanks for your warm regards. We'll take your comments with a dose of ROAD salt. If you're not careful, we'll come down there for a visit.
-Northerners, we chill
Old 09-25-2003, 09:39 AM   #12
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
dont belive the south doesnt have to winterize. it is no fun fixing split pipe and i have had to do it. end of jan / feb it gets cold and freezes here. maybe not in tampa but in northern alabama .
i blow the water out of the lines and drain the heater. and put a shot of anti freexe in the heater. not all of the water will drain out.
i also drain the fresh water tank. that works for me.lol
al
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 09-25-2003, 10:41 AM   #13
1975 29' Ambassador
Reno , Nevada
see
http://sierranevadaairstreams.org/ow...nterizing.html
for some ideas and links and pictures
The problem with water and blowing out the system isn't the lines so much as it is residual water left in the valves, especially complex valves such as the single handle valves or the toilet rinse valve. Also watch out for accumulator tanks, sink spray hoses, shower head hoses and lines, and water filters.
The water heater is drained by removing its drain plug which is usually available just behind where the gas supply line goes to the control valve. A X type lug wrench usually works good on this plug as it is (usually) a standard half inch pipe thread plug.
Old 09-25-2003, 04:45 PM   #14
Castaway
Poor Royal's Avatar
Appalachia , Pennsylvania
Help!
I just had my trailer winterized at my local SOB Dealership. Although I usually have (most of) my work done in Jackson Center, I thought this was a simple procedure. What a nightmare!
I decided to stop by yesterday while they were working on it, and they had the whole cupboard under the sink ripped apart, and under the stove all torn out, looking for the water pump.
He ďthenĒ ask me if I knew where it was. (he had my phone number, why didnít he call me FIRST?) I said, I think I read it was under the wardrobe closet. He said that is where is was going to look next...
He then proceeded to rip the closet apart, doors and all. Anyway when I went to pick up the trailer, the kitchen sink doors didnít open or shut properly like before, screws werenít screwed back in the whole way on the furnace vents, and a host of other things.
Then they denied they had anything to do with the doors no longer closing properly, saying they never touched the doors. That is bull, because I practically lived in the trailer this summer and KNOW the doors worked properly. He then proceeded to give a few snide remarks about Airstream TrailersÖ He said the doors do not close properly because the kitchen sink does not have enough support to hold it up, and he took ahold of it and pulled it back and forth with all his might, Practically rippping it out from the wall!
MY QUESTION IS: I ask him if they put any antifreeze in the black and grey water tanks. He said they didnít because they holding tanks are supposed to be drained for the winter and they donít need antifreeze. He said I should empty them out before storing it. They both have a few gallons of clean water in them.
I always read never to let the tanks sit dry. Are you supposed to empty them out, and do I need to add antifreeze in them? Also, do they really have to rip my closet apart every year to have it winterized?
I have a feeling there is going to be all kinds of problems next spring when I go to use it.
Sorry so Long....... Grrrrr
Poor Royal is offline   Reply With Quote
Winterizing and Waterfilter overlander76 Winterizing, Storage, Carports & Covers 12 10-21-2004 09:59 PM
Adding a fan to the fridge Stefrobrts Refrigerators 31 04-10-2004 06:07 PM
winterizing question Stefrobrts Winterizing, Storage, Carports & Covers 11 11-03-2003 04:11 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 03:32 PM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
