Old 10-26-2005, 07:45 PM   #1
hummerdinger's Avatar
winterizing a 1974/no bypass
Need help, my Ambassador does not have a bypass on water heater. I can't figure out where the bypass can go, can't get good access to lines. Anybody have experience with this model? Otherwise I have to pump alot of pink stuff.
1974 Ambassador 29
2005 GMC Sierra 2500 Crew Cab SLT Duramax Diesel
Pittsburgh,Pa.
hummerdinger is offline   Reply With Quote
Old 10-26-2005, 08:12 PM   #2
1960 24' Tradewind
Riverside , California
Copper tubing! In a tight spot. You could make a temporary bypass for the water heater, undo the copper tubing flare nuts, IF you have enough room attach a 90 1/2" mpt x 1/2" flare fitting to the flare nuts and a short 1/2" x 1/2" sink hook-up hose between, then the heater is out of the system. Compressed air does a good job of winterizing (watch the P.S.I.) blow-out plugs are cheap and if you do each appliance individually you can have enough force to push most of the water out....but nothing like a little antifreeze, don't forget the "p" traps and drain all the tanks.
Greg
ZoomZoom is offline   Reply With Quote
Winterizing Tips niftypkg Winterizing, Storage, Carports & Covers 144 01-22-2009 07:06 AM
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
Water heater bypass niftypkg Water Heaters, Filters & Pumps 0 05-15-2002 05:38 PM
