Old 10-27-2008, 06:33 PM   #29
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by Wayne&Sam View Post
Per the directions in the Safari manual, disconnect the lines to the pump and run it a few seconds to get the 1/2 cup of water out.
WOW, someone else who reads the book! It doesn't have all the answers but sure give the basics.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 10-27-2008, 07:20 PM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Antique Pedaler View Post
For nine years, now, I drain the lines, drain and bypass the water tank, blow out the lines with compressed air and put a small amount of rv antifreeze down each drain. That's all AS Customer Service said they do in Ohio and my trailers have survived 9 Wyoming winters with no problems.
Ditto in Buffalo
My DW has a real aversion to anything toxic.
I have never introduced anti-freeze to anything other than the traps.
I have an air chuck that will fasten directly to the blo-out fitting, allowing me too alternately open and close all taps while raising and lowering the trailer, and cycling the water pump. (approx 10min@50psi) I have disconnected the pump after this procedure and less than a tablespoon of water came out, don't know if it has ever frozen in the pump, but Iv'e never had a failure. Leave all faucets and drains open, shower head open and on the tub floor.
Keep the critters out of the tanks with pieces of Scotch-Brite rubber-banded over the drains.
Been Stream'n 22yrs. here in Bflo. with never so much as a squirt.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 10-29-2008, 04:40 AM   #31
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Originally Posted by ROBERT CROSS View Post
Ditto in Buffalo
RV antifreeze is non-toxic. You can drink the stuff. You probably won't like it, but it won't hurt you.
Here's the link to the PEAK RV/Marine antifreeze MSDS.
Roger
Old 10-29-2008, 06:43 AM   #32
Thumbs down Big Pink
Roger
Yes but it's PINK and it tastes terrible, I have given up trying.
And she's not happy, til I'm not happy.
PFC
"Tahawus"
RLC
John Prine
Old 10-29-2008, 11:52 AM   #33
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
That sounds great. But what special attention do you give the water pump?
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 10-29-2008, 06:08 PM   #34
Question If your ask'n me?
Bob,
When we took delivery it had a 1/2 tank of freshwater. It sat on the Dealer lot 4mos. Had to flush out system and prime the pump. No fun. Disconnected lines and pumped bleach solution thru. After blowing out (45psi) the lines only about an ounce came out. From then on I just, tilt and drain with everything open. Drain water heater, Open pressure relief valve,blow out tank, leave open with a green scrubby wrapped around drain. Pour the pink stuff in all the traps, and leave all taps open. Thats about it.
PFC
"Tahawus"
RLC
John Prine
Old 11-17-2008, 07:27 PM   #35
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Bit the bullet today, took a half day off from work and winterized. Got it done and was pouring antifreeze into the drains and then the lightning bolt hit me....forgot to winterize the kitchen sink sprayer and the toilet spray. Reconnected the antifreeze hose to the pump and pumped out the water that was present in these two hoses.....glad I didn't forget. I've been winterizing for almost 30 years but the Classic is my first trailer with sink and toilet sprays. This is my 4th winterizing of this trailer. Still hard to remember these two important pieces....don't you forget.
Also if you have an outside outlet, don't forget to winterize that!
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-19-2008, 04:39 PM   #36
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
when winterizing. my 1989 31 has the water pump then the regulator. I cannot get water back thru the city water hook up???. My 71 I just turn on the pump the open the outside valve and it feeds back. Not so on my 89. Is this normal? how do you guys do it.
mustang is offline   Reply With Quote
Old 11-19-2008, 06:48 PM   #37
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The original question was about a 1974, so the answers may be different. For our water heater (read the owner's manual) there's always up to 2 gallons of water in it and that's ok. They recommend flushing it out because it won't corrode as soon. You'll never get it all out unless you turn the trailer upside down. On the bypass on ours, there a 4th valve which drains some water out of the water lines and down to the ground. This is in addition to the plug on the water heater. If you have the kitchen sink water filter, remove it so you don't get any antifreeze in it. Don't leave it in the trailer as there will be water in it and it's not easy to get it all out.
Some Airstreams have the water pump in an inaccessible place, so I had ours moved and turned around so I could get to the filter to clean it. There are bypass kits for the water heater and that makes it easy to pump antifreeze through the pump and into the lines. It takes a lot of antifreeze to fill the lines.
I blew out the lines first after opening all the drains—fresh water tank, the two for the water lines and the water heater. Then when nothing comes out of one, close it and check the next. Make sure if you have an outside shower to disconnect it and blow out the pipe there. Disconnect the shower head and let the flexible pipe down to the drain and make sure it empties. Put some antifreeze in all the tanks and in the toilet to keep the seals lubricated.
I don't know how antifreeze tastes because last spring we flushed out everything. We used a mild solution of Clorox and run it through the system, both through the fresh water tank and the city water connection. Flush twice with it, then flush some more with clear water, then flush again. Leave the grey water drain open and let it run out on the ground—it's clean and nontoxic. With or without antifreeze in the lines, I want to thoroughly clean out the system because any bacteria that may be there will multiply over time and could be really nasty by Spring.
I forget to check the sprayer hose (thanks Jack) on the sink—better do that tomorrow. I don't think I did it last year and got away with it.
It takes longer in the Spring to flush out the system than it takes to winterize it.
Gene
Old 11-25-2008, 02:28 AM   #38
Yomster's Avatar
1968 26' Overlander
London (UK) / San Francisco , London / California
Images: 13
What advice would you give to an Airstream stored in Reno, and is there anyone who could help winterize a '68 Overlander? I was hoping to be back in the US but work dictates I remain in the UK.
Y
Yomster is offline   Reply With Quote
De-winterizing frozen chosen Winterizing, Storage, Carports & Covers 9 12-06-2007 07:14 PM
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
Help with winterizing snpotratz Winterizing, Storage, Carports & Covers 31 12-18-2006 08:27 PM
Winterizing JulianneJ Winterizing, Storage, Carports & Covers 25 11-22-2005 06:15 PM
Winterizing... PWRSTRK Winterizing, Storage, Carports & Covers 15 10-09-2004 08:30 PM
