Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 11-15-2007, 08:15 PM   #1
transplant
transplant's Avatar
Profile:  2005 30' Classic
brentwood , Tennessee
winterizing
hi we need to winterize our a/s and want to know if it is safe to go to a place like camping world for this or a local sob place. is there anything special that we need to have done???? we are newbies and don't want to make a mistake.
a dealer is too far for us to go right now.
thanks so much for your help.
transplant is offline   Reply With Quote
Old 11-15-2007, 09:06 PM   #2
SilverCottage
SilverCottage's Avatar
Profile:  2007 27' Safari FB SE
LONDON , ON
Check out some of the other threads on winterizing, buy yourself a compressor and do it yourself! Two seasons will pay for the compressor and you will have the satisfaction of knowing the job was done right. It is really not that hard to do.
SilverCottage is offline   Reply With Quote
Old 11-15-2007, 09:19 PM   #3
transplant
transplant's Avatar
thanks for quick reply. we are not able physically at this time to do it so thought we could have someone else do it.
our weather here has been in the 40's and we will not use a/s untilfirst part of dec and then after christmas. i have mixed feelings about what to do. any expert advice will be
appreciated.
Old 11-17-2007, 11:08 AM   #4
remled
Profile:  Currently Looking...
Choctaw , Oklahoma
Thumbs down remled
Most RV service centers will do this for you and do a good job......best is an Airstream dealer if available or a certified AS repair location......Good luck.
remled is offline   Reply With Quote
Old 11-17-2007, 12:30 PM   #5
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
In the meantime turn your furnace on at a low setting for those below 32 degree nights. I leave mine on at 45 degrees inside when there is danger of a freeze, until I winterize for the Jan-March times.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 11-17-2007, 01:33 PM   #6
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Check ahead of time that whoever does your winterizing will guarantee against any freeze damage. I have heard from a lot of people who had a bad job done which resulted in broken lines and got an oh well response from the rv guy.
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 12-06-2007, 12:06 PM   #7
fltlevel510
Profile:  2004 30' Classic Slideout
. , Kentucky
Winterizing your home
How about we flip the winterizing question to how do you winterize your home when you go South for the winter.
Furnace off or on. If on what temperature?
Water off, do you drain lines in the house.
What about lighting?
Grill and porch furniture in storage.
fltlevel510 is offline   Reply With Quote
Old 12-06-2007, 07:00 PM   #8
*ship capt
*ship capt's Avatar
Profile:  2008 23' International CCD
Cordova , Tennessee
Question Installing Winterizing hose
We have a 23' International and am wondering if anybody has simple directions to installing an RV antifreeze winterizing hose in the access space by the water pump. I have used an old pump attached to a scrap of plywood. Using the installed pump would be a lot more convenient.
*ship capt is offline   Reply With Quote
Old 12-06-2007, 08:36 PM   #9
mistermcfrug
Santa Fe , New Mexico
Maybe this comment is more appropriate for next year. Bottom line, I think it is a waste to pay a dealer to do a job that is easily done yourself. Besides, when you carefully follow the below steps, you KNOW it's done right and won't ever have to hear excuses from a dealer when something freezes because a worker was in a huge hurry.
I've found the best and easiest way to prepare for winter is to go to a truck stop when you're returning from your last trip of the season. Truck stops have free, powerful air that you can take your time in using. This is much better than those poor quality, "stick in the quarters" compressors at gas stations.
Purchase a water pressure protector from a RV shop. These cost about $7. Also purchase a air hose adapter that is intended to to be screwed into the city water supply port on your trailer. You will screw the air hose adapter into the pressure protector, not the city water supply as described below.
(1) Carefully drain, on level ground, the fresh, gray and black tanks.
(2) Before you go to the air hose at the truck stop, use a racket set to remove the water heater plug and drain the water heater. When the water starts to flow after the plug is removed, I quickly hold a 1" diameter, one foot long cheap plastic hose to the plug port so that water doesn't touch the surrounding electrical parts.
(3) Next, follow the directions in your Airstream users manual to by-pass the water heater. The above steps are very, very easy.
(4) screw the air hose adapter into the air pressure regulator or protector and then screw this assembly into the city water supply port. The reason I recommend a pressure protector is to make absolutely sure that you don't use more than 65-70 psi. On the other hand, you are going to a truck stop because cheap air compressors that you buy aren't likely to give you the confidence that you have completely blown all the water from the lines. You want full 65 psi air and LOTS OF IT.
(5) insert the air hose from the truck stop into the air hose adapter assembly described and open one faucet at a time and allow air to blow all the water out. Take your time, don't be in a hurry. Remember to switch the faucets from cold to hot so you get all the air out. Be sure to get all water valves--the outside shower, kitchen faucet (don't forget the sprayer), bath faucet, inside shower, and the toilet valve!
I've found that it's handy if your spouse operates the air hose while the most knowledgable person drains the valves. You can easily see the water blow out the faucet or sprayer heads and know when all water is out.
This only takes about ten minutes.
Next, pour about 8 ounces of a 50/50 mixture of RV anti-freeze and water into the bath sink and kitchen sink. RV anti-freeze is sold at a reasonable price at all Wal-mart SuperCenters I've seen. This protects the "P' drain pipe.
After I get home, I also pour 15-20 ounces of RV anti-freeze into all the tanks when the unit is finally parked. This is just in case not every last drop of water drained from the tanks.
At the beginning of the next season, flush the RV-anti-freeze out of the fresh water tank. Because it is RV anti-freeze, there is no danger of toxicity.
If you have a question, I don't mind a call at 505-988-2131. I store my trailer in the mountains of New Mexico at over 8,000 feet so I know the above steps work.
mistermcfrug is offline   Reply With Quote
Old 12-06-2007, 08:36 PM   #10
Sky
Sky's Avatar
Profile:  Sum Wear , Ohio
This thing works pretty good.
Pump Converter Winterizing Kit : JC Whitney: Auto Parts & Accessories
"Some people walk in the rain, others just get wet" - Roger Miller
Remembering games and daisy chains and laughs" - Roger Waters
Hubba - 2006 2500HD DMax............Bubba - 2007 30' Classic w/ Hensley
Sky is offline   Reply With Quote
Old 12-07-2007, 06:11 AM   #11
*ship capt
*ship capt's Avatar
Cordova , Tennessee
Thumbs up Bingo!
Sky - Thanks, I will get one of these kits on order and install it. It looks like exactly what I need. See you around the campfire.
Old 12-07-2007, 06:21 AM   #12
SilverCottage
LONDON , ON
That's what I used but it is a few $ less at Camping World:
Pump Converter Winterizer Kit - Camping World
Old 12-07-2007, 07:05 AM   #13
*ship capt
*ship capt's Avatar
Cordova , Tennessee
Thumbs up Even better!
Silver Cottage - Thanks. The difference will help pay for the antifreeze. As I become more experienced I should learn to check CW first on a lot of things. You and Sky are really helping a rookie get started right.
Old 12-07-2007, 07:21 AM   #14
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
The PO of my trailer installed one of these kits.
I have never used it.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
De-winterizing frozen chosen Winterizing, Storage, Carports & Covers 9 12-06-2007 08:14 PM
Help with winterizing snpotratz Winterizing, Storage, Carports & Covers 31 12-18-2006 09:27 PM
Winterizing in N. FL ? Soarhead Winterizing, Storage, Carports & Covers 5 11-26-2004 08:29 AM
Winterizing... PWRSTRK Winterizing, Storage, Carports & Covers 15 10-09-2004 09:30 PM
What about de-winterizing cosmotini Our Community 5 03-03-2004 05:59 PM
