Originally Posted by Woosch
If you have never done it before, I would recommend hiring someone to do it this year then do it yourself next year. Its really not that expensive. One question you need to answer is wether you will fill the lines with anti freeze or use just enough for the P-traps and toilet(for me its about a gallon) My guess is that you may opt for filling the lines because of your cold winter temperatures.
I have attached the checklist that I use.
Also, backing up. I found that putting my hand at the Six O'clock position made it easier for me. That way, if you want the trailer to go right you move your hand to the right. Get a feel for what a quarter turn does and what a half turn does. Practice is the key.
Good luck!
Thank you for including the Airstream Winterize Checklist. I'm curious about the water filter under my sink and what i'm to do with it when blowing out the lines. I have a
2008 23FB. in the checklist it mentions to remove the filter canister. Am i to assume thats all i have to do before blowing out the lines?
Mike
