Old 10-03-2016, 09:03 AM   #1
2016 26' Flying Cloud
2011 25' FB Flying Cloud
reno , Nevada
Winterizing
As winter is almost here, its time to winterize...Any ideas on the easiest way
to get this done? I will probably be using it a couple of times during the winter, so I will have to do it multiple times.
Thanx for any help.
jomondnv is offline   Reply With Quote
Old 10-03-2016, 10:11 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
More than one way to skin the cat but this is what I do:
1. Drain the tanks, lines and low point drains
2. Use the water pump inlet to pump RV antifreeze. (kit makes this easy)
3. Open faucets till antifreeze comes out, pour a little in sink and shower drains
4. Water heater bypass will save you a lot of time, and work
Lumatic is online now   Reply With Quote
Old 10-03-2016, 05:49 PM   #3
LilBigfoot's Avatar
London , Ontario
26u
You'll need to add this water heater by-pass kit from Camco. Installs on your pump connections. Will suck the RV Anti Freeze through the system. http://www.camco.net/product/pump-co...ing-kit-10271/ It was an easy mod for me....I did have to raise up the pump about 1/2" to clear the bottom board...see post 84 http://www.airforums.com/forums/f516...-139457-6.html
Then read from post 135 as Kaunut had a bit of a work around.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
