Old 09-12-2015, 06:49 PM   #1
lkm4321's Avatar
2015 27' Flying Cloud
Cedar Rapids , Iowa
Winterizing
Live in Iowa and my first year to winterize. Rather then blow out all the lines, could you just put 2-3 gallons of food grade antifreeze in the fresh water tank and pump it through to the gray and black water tanks ? When it's time to dewinterize just flush it all out ? Thanks for your comments. 2015 FC
lkm4321 is offline   Reply With Quote
Old 09-12-2015, 07:12 PM   #2
Normal , Illinois
That's what I do.
Make sure you run the antifreeze thru everything that water goes thru, inside and out.
Maggie
Old 09-12-2015, 07:29 PM   #3
1987 25' Sovereign
Oregon , Ohio
There is a winterizing kit that you can install between the water tank and the pump. It is available at Camping World. When installed The pump will suck the antifreeze out of the jug. I only use 1 1/2 gallons to do our 25' Sovereign and we have not had any issues yet and we live in NW Ohio.
msmcv51 is offline   Reply With Quote
Old 09-12-2015, 07:48 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I would blow out the lines before putting in antifreeze to avoid dilution from the water left in the lines.
The water pump in my trailer is installed at an angle that would make putting a winterizing kit on very difficult.
CRH is offline   Reply With Quote
Old 09-12-2015, 07:55 PM   #5
ericpeltier's Avatar
Superior , Colorado
I do not blow out the lines prior to antifeeze. I just make sure it runs VERY pink from all the lines before calling it good. I'd rather use an extra gallon of antifreeze than bother blowing out the lines.
Yes, you could pull it from your tank.
Remember to remove the water filter, if you have one.
ERic
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-12-2015, 08:04 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
If you have an Everpure water filter, you need a bypass plug to get the water to the spigot.
Old 09-12-2015, 08:50 PM   #7
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I have never heard of this plug before could you give us a bit more info
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-12-2015, 09:03 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
Out of Doors Mart is where I got mine. You take out the filter cartridge and put in the plug. You can then turn on the water supply valve and let antifreeze go thru the line to the spigot.
Old 09-12-2015, 09:49 PM   #9
1974 25' Tradewind
Calgary , Alberta
Make sure you drain the water heater tank (unless you have a tankless system) and set the water heater bypass valve correctly, or else you will end up filling the heater tank (six gallons!) with antifreeze before getting to the rest of the hot water plumbing.
To get the stuff to go everywhere you need, start the pump and then open one faucet at a time (start closest to the pump) and run the faucet until you're sure you're getting enough pink. Remember that the hot and cold are separate circuits and you need to do them both. Don't forget the toilet flush valve.
Having said all that... after the first or second year of doing this and having to put up with pink frothy bad-tasting water in the plumbing for half the next year on our white box trailer, I made up an air-chuck-to-garden-hose adapter that I could screw into the city water connection, and since then I've winterized by blowing the lines out with air at 50 PSI. Same stuff applies about doing one faucet at a time.
Alumineer is offline   Reply With Quote
Old 09-13-2015, 06:15 AM   #10
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Don't forget to blow out the black flush line with air. The is a plastic one way valve on this line that will break if it has water in it that freezes. Blowing out the lines also insures the water pressure regulator behind the city water hookup is free of water.
Then you can fill the system with antifreeze.
Kelvin
Old 09-13-2015, 08:27 AM   #11
Arcticfox's Avatar
Central , Canada
Blowing the lines from this location sounds like a slick way to handle winterization. How do you deal with residual water in the pump? Also I'm assuming your bypassing the water tank and just draining it?
Doug
Old 09-13-2015, 08:47 AM   #12
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I use a blow plug screwed onto the city water inlet to blow out my plumbing lines.
Blow-out Plug - Camco 36104 - Winterizing - Camping World
Hiho Silver is offline   Reply With Quote
Old 09-13-2015, 09:50 AM   #13
1976 31' Sovereign
Oswego , Illinois
How ever you winterize do it properly or else expensive fix next year. As others have suggested blow lines, run anti freeze thru lines etc. A must is drain fresh water tank, water heater and gray and black tanks. Pur. water heater bypass kit, water filter plug as anti freeze will ruin cartridge, make sure anti freeze in all drains if not put in 1 cup each drain also into toilet. I would never put anti freeze in fresh water tank. I made by pass for fresh water to pump with some screw in barb fittings into tee and 2 valves, and a piece of hose to suck anti freeze from jug, or else can pur. kit to by pass pump.
Old 09-13-2015, 09:54 AM   #14
1976 31' Sovereign
Oswego , Illinois
Smile winterizeing
Doug
Just run pump until dry, water gone pump can run dry without damage.
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
