Old 10-06-2004, 01:46 PM   #15
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Compressed air
I have only used antifreeze in the lines one winter, and I don't plan on ever bothering again. Other than that year, I have just blown the water out. In my 34', after draining the freshwater tank and both holding tanks, and blowing out ALL of the water (let the air flow for a couple of minutes AFTER you see the last water droplets come out of all of the faucets including the shower...) I also just open my pump's pre-filter and drain it as well as removing the fittings to the pump just to make sure it's drained. The pump and pre-filter are probably the most difficult things to do, and they only take a couple of minutes.
I do pour RV antifreeze into the drain P-traps. Once the freshwater tank is drained, I'm not particularly concerned about whether or not there's a little left in the tank. I've never had any problems with it. I generally remove my batteries too, and store them in the basement as they're kind of expensive to let die 'cause I was too lazy to pull 'em out.
Roger
Old 10-09-2004, 08:30 PM   #16
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Winterizing is very easy. Check out this website
Originally Posted by PWRSTRK
I'm just darn worried about our first winterizing.
I think I want to have it done professionally the first time or two or three. Our dealer is four hours away -- is it safe to have it winterized by a non-airstream RV dealer? (There is one here with which we have another relationship.)
Tom (and Frank)
Really simplifies the process and it has pictures, too!!!
http://www.rverscorner.com/articles/painless.html
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Winterizing Tips niftypkg Winterizing, Storage, Carports & Covers 144 01-22-2009 07:06 AM
Winterizing and Waterfilter overlander76 Winterizing, Storage, Carports & Covers 12 10-21-2004 09:59 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
