Old 03-20-2011, 10:29 PM   #1
2006 19' International CCD
Amelia , Ohio
Winterize For One Night?
We just got home with our new-to-us '06 19' Int'l that we camped in on the trip back from Vegas. Now that we're home in Cincinnati, the forecast is for a low of 29 deg. F one night this week. My question: do I need to winterize for possibly the last cold night? The owners manual says the tanks are heated when winter camping, so f I just leave the furnace on for this one night, will that solve the issue?
Sorry for the newb question, but it's our first A
Cheers,
Tom
jambie is offline   Reply With Quote
Old 03-20-2011, 10:35 PM   #2
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
If you leave the heat on, you should not have any problems with any freezing pipes etc.
Charles
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 03-20-2011, 11:04 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Leave your furnace on and your lower cabinet doors open....you should be fine for one night @ 29 as the low. Just hope the predictions ring true and it doesn't go lower for longer.
Shari
Old 03-20-2011, 11:24 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We were in Texas the beginning of February just in time for their freeze. We did just as Shari said, furnace on low, lower storage doors open. It got into the teens several nights, no problem. Make sure you are plugged in so that the furnace does not run your batteries down, also be sure you have propane.
You should be just fine.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-21-2011, 12:28 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We were camped in Tucson last month when in went down to 17 deg F. Heat on and cabinet doors open, propane hot water heater on, and elect tank heaters on. Disconnected outside water supply and opened faucets to release any pressure should ice form and expand in the lines. No problems.
Old 03-21-2011, 12:35 AM   #6
Amelia , Ohio
Are there separate switches/controls for these?
Cheers,
Tom
Old 03-21-2011, 05:54 AM   #7
blmitch5's Avatar
Olathe , Kansas
Cheers,
Tom
I also have an 06 Bambi CCD. It relies on the furnace to heat the tanks and lines. Just do what's been suggested (empty the tank and lines) and run your furnace at a low temp if you think it will fall below freezing. Congrats on your previously enjoyed AS!
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 03-21-2011, 06:11 AM   #8
1986 31' Sovereign
Miami , Florida
If you have the heat strip option on your a/c, leave it on and set the furnace to 60 or so. You'll be fine and the haet strip will save you some propane.
mike
n2916s is online now   Reply With Quote
Old 03-21-2011, 06:18 AM   #9
Ottawa , ON
Two things to consider:
First, what is your level of confidence in the accuracy of your weather service?
Then, perhaps think back on your luck in Vegas.
Old 03-21-2011, 06:50 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
That's pretty much what we do here. Inevitably it's late in the day when we arrive back home, and inevitably it'll be cold at night. Plug the thing in, turn on the heater, and hit the sack.
Lynn
WBCCI 21043
Old 03-21-2011, 07:15 AM   #11
Bird's Nest's Avatar
2007 19' Bambi
2005 18' Westphalia
Evans , GA
Prop open the door to your bathroom and take the panel off in front of your water pump.
Open the faucets. Pull out the kitchen wand and leave it in the sink.
We would use a space heater with a thermostat in our CCD.
Our Westy is plumbed so that we can winterize and de-winterize in minutes. We used it all winter and winterized it several times. I wish it could be so easy for the tow-behinds.
Bird's Nest is offline   Reply With Quote
Old 03-22-2011, 10:06 AM   #12
blickcd's Avatar
Milford , Ohio
Tom,
Hello neighbor, I live in Batavia.
As others have suggested, running the furnace for a night should be okay. It isn't supposed to get really cold but opening cabinet doors and access to the water pump compartment are a good idea anyway.
A few other suggestions are to, with the water pump off, open all valves just to bleed pressure off the system. Also make sure you have enough propane as the furnace burns it up fast. Maybe have both LP tank valves open in case one tank runs out and the regulator switches over. I assume you are plugged into shore power so you won't run down the batteries with the furnace blower.
Christopher
blickcd is offline   Reply With Quote
Old 03-22-2011, 01:34 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We were here in Tucson, too, and did the same thing and were fine...and we had temps in the teens for 2 or 3 nights is I recall... It's best to use propane furnace to keep things warm because an electric heater won't take warm air to the tanks...just make sure you don't run out of propane, and be on shore power if possible so the batteries aren't drained... I keep the water heater running and run hot water through the pipes before we go to bed...if I get up during the night I run hot water through the pipes again...
TB & Greg and Abbey Schnauzer
#3954
Old 03-22-2011, 03:29 PM   #14
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
mike
The only caution on this solution is that the furnace is ducted to areas that the heat strip warmth may not easily reach. Leaving the furnace on can be a secondary backup, but the heat strip may produce just enough heat to keep the furnace off, which may in turn not deliver critical heat to areas that could drop below freezing.
Keep in mind that water has a strange property that causes it to expand dramaticly as the temperature hits freezing. That's where the damage is caused as the ice forms as you go below 32 and water volume at freezing expands 9-10%.
My advice is run the furnace and open up the closet doors. I've done that in the past when we dewinterized early and got hit by some late cold snaps.
Jack
Jack Canavera
STL Mo.
AIR #56
Quilting and Airstreams SilverHoot Off Topic Forum 831 06-23-2015 04:47 PM
What an adventure! Evacuated the 2nd night in our AS DJW On The Road... 6 03-13-2011 11:22 PM
Good Night all!!! THEPILL Off Topic Forum 19 03-03-2011 12:46 PM
A Newbie and Her 'Fly at Night!' Fly at Night Member Introductions 34 02-24-2011 11:41 AM
