Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 09-29-2009, 07:31 AM   #1
Profile:  2009 23' FB Flying Cloud
Bowling Green , Ohio
Winterize and protect new AS & trip in the winter
First frost predicted already here in Ohio!We got our 2009 AS in May of this year. I have the article by Janet H on winterizing. Ours will be sitting outside as winter approaches. Can I assume this new AS has clear coat and outside is protected? Any other suggestions?
Also we plan to pull it out of the snow to head for Texas in February. Any cautions from you experts on that? We figure we can plow the pad ahead of it and pull it out so long as we are not buried in snow. I assume we will have to winterize it before we return home from Texas after a couple of weeks. Are we crazy?
Karterlin is offline   Reply With Quote
Old 09-29-2009, 08:02 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
See the first 2 threads here - http://www.airforums.com/forums/f458/ -- especially the step-by-step by john hd.
I thought my water pump access was tight when I put the Camco valve into my Safari. But I've got a buddy with a 23' International and access is nearly ridiculously tight. You've got to reposition the water pump 1.5" or so to fit the valve. We've got to look at it again but I'm wondering if he's going to have to go with a dealer blowout job.
Remember to put antifreeze in the traps.
Old 09-29-2009, 08:42 AM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
If you are going to travel over salt laden roads, make sure you wash your trailer and frame once you get out of the cold and salt. I had a friend who pulled back from Texas to Missouri one spring and had to drive on roads which salt had been spread. His frame broke out with small rust marks all over. All areas where the paint had been dinged by rocks or was thin. It was pretty surprising. It looked like the trailer frame had a case of the measles.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 09-29-2009, 11:34 AM   #4
doug&maggie's Avatar
Profile:  Normal , Illinois
We had to get a tow to lift our Interstate out of its' frozen rut last January, so be prepared.
We only de-winterize once we are clearly out of freezing weather. Watch the forecasts and remember that the border states do not plow and salt like we Midwesterners do.
li'l moose
The more you know, the less you need
doug&maggie is offline   Reply With Quote
snow heat snow in 2 weeks
Winter Trip recomendation: Eagle viewing Gen Disarray On The Road... 36 12-06-2007 05:07 PM
winter trip gas, desel and LP imagine Winter Living 4 09-10-2007 12:42 AM
Strip & Polish ..In the Winter Julison Cleaning, Stripping & Polishing 3 11-26-2005 10:22 AM
A winter trip to the dealer jcanavera Our Community 2 01-07-2005 06:42 AM
Mid-winter trip Pahaska On The Road... 2 01-12-2004 10:36 PM
