10-01-2019, 08:13 AM
2016 30' Classic
Colorado Springs
Winterization / water heater bypass valve
I intend to blow out my water lines with compressed air. If the water heater bypass valve is on (in bypass mode) does that mean that the water heater tank will not be pressurized when I apply compressed air to the utility water input?
10-01-2019, 08:19 AM
1995 25' Excella
xxxxx
, xxxxxx
Yes
10-01-2019, 08:48 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Once in by-pass mode, drain the water heater at the outside access panel, and leave it in by-pass mode as you purge the water lines with compressed air.
Don't forget the toilet and the shower.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
10-01-2019, 10:00 AM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
Also don’t forget outside shower. And hit your black tank flush with compressed air to clear it and esp the antisiphon valve. And go all around the low points a few time as well.
10-01-2019, 11:13 AM
2016 30' Classic
Colorado Springs
Thx all for the replies
Vince
10-02-2019, 09:34 AM
2016 30' Classic
Colorado Springs
Also... I’d like to wait a few weeks before “sucking” some anti-freeze into the water pump head. Temperatures here in Colorado Springs are not expected to dip below freezing but may approach freezing-question is: how sensitive is the pump to freezing? Is there much risk to the pump if the temperatures do not dip below freezing for a prolonged period. Thx in advance for replies / advice.
Vince
10-02-2019, 09:38 AM
2016 19ft flying cloud
Spokane
Don't forget the spray nozzle on your kitchen sink
10-02-2019, 09:58 AM
2004 30' Classic Slideout
Fenton
, Missouri
Setting the valves in bypass mode and then blowing out the lines could, dependent upon your plumbing for your trailer, might leave some water in the lines between the valves and tank.
Dependent upon the positioning of the bypass valves and shut offs, I advise folks to blow the lines out with the bypass valves being set in their summer position, then switch them to their winter position to bypass the water heater tank and continue blowing them out. This will remove any water that could be trapped between the valves and the tank.
Setting the valves in bypass mode and then blowing out the lines could, dependent upon your plumbing for your trailer, leave some water in the lines between the valves and tank.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-02-2019, 10:01 AM
Fenton
, Missouri
And that spray hose for the toilet if your toilet is so equipped. Also your add antifreeze to the kitchen, bathroom sink drain traps and the shower drain traps.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-02-2019, 11:14 AM
1964 26' Overlander
Milton
, ON
Vince
This might not be convenient on all trailers, but I take the pump out when I winterize. It takes less than a minute - just one wingnut and two water connections. No tools required.
10-02-2019, 12:43 PM
Albuquerque
, New Mexico
Jack Makes an Excellent Point
Jack
Whereas this has never been a problem on my previous two Airstreams, a visual inspection of our new 2019 suggests that I should try Jack's approach when I winterize this year.
10-02-2019, 01:17 PM
2016 25' Flying Cloud
Holly Springs
, Mississippi
It's seldom found on winterization checklists, but I recommend removing the batteries from your television remotes and from the smoke detectors. Those can and will go bad during the winter and ruin your changers.
Put fresh batteries in in the Spring.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
