08-18-2014, 08:24 PM
Watertown
, Massachusetts
winter storage questions
We just got our first AS. There is quite a learning curve! Although it's early, I'm thinking about the winter - it always sneaks up on me!
Anyway, we have a small city lot in the Northeast, with a two car garage and a two car wide driveway. The AS is parked on one side of the driveway, and we have our two cars beside the AS - one in the garage and one on the driveway.
We can already see that this is going to be trouble, especially in the winter when we have to shovel out. On one side of the driveway is a grass area about 3/4 the size of the two car wide driveway. If we move a fence back into the yard a bit and remove a raised flower bed and cut another one off a bit, we could park the AS there for the winter, clearing out the driveway and allowing both cars to be parked in the garage so the driveway can be plowed.
So my questions are - (1) should we put a tarp or something down on the grass, or just park on the grass? (We are thinking of putting in a driveway space there, but may not get to that this fall as it also involves removing part of the sprinkler system.)
And since this is a small lot, the space I could create by moving the fence is 26', and the AS is about 21'. That puts the AS a max of 4' from the 3' sidewalk, and the sidewalk is pretty much right next to the street. They use salt on the streets, spread by those machines that sort of spray it out the back. I'm thinking that will be hard on the finish. So (2) how can I keep the salt off my AS?
Hubby is thinking of a plywood thing shaped sort of like a tall cow catcher. Would that do it? Obviously, we need to make sure it doesn't take off with the wind and cause damage in the process. We can probably just U bolt it to the trailer hitch and maybe use tent stakes to hold it down securely and somehow make sure it doesn't rub on the skin of the trailer. Any idea how tall this "salt catcher needs to be?
Or, is there some other easier method of keeping the road salt off? Maybe a tarp on the bottom half of the font?
08-18-2014, 08:33 PM
1972 25' Tradewind
Hopkins
Firstly, check with your city/municipality. Some do not allow recreational vehicles to be parked on the grass.
08-18-2014, 09:16 PM
Watertown
, Massachusetts
Ah yes, the town regulations! I've seen other people park on grass, but I'll still check.
08-18-2014, 09:39 PM
Broadway
, North Carolina
Our last storage lot was a grass field on a farm. The wheels sunk in and were always muddy so I bought two 8ft pressure treated 2x10's and drove it up on those. Much better. Our new storage lot is gravel but I still use them.
If you are near water in Mass, there are sometimes mobile shrink warp companies that wrap boats for the winter.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
08-18-2014, 09:48 PM
Watertown
, Massachusetts
Shrink wrap
We do have a dock in town, and I see the boats wrapped for the winter. I don't know if they are mobile or not.
But I understood that you weren't supposed to cover a trailer -covers trap moisture inside and cause trouble. Did I misunderstand?
08-18-2014, 10:01 PM
Broadway
, North Carolina
That I do not know. No moisture will get past it like with a canvas or poly cover in the first place. I cannot see that the effects are much different from wrapping a boat but maybe the local marina knows.
http://mobileshrinkwrapping.com/
2006 Safari SE FB
Broadway, NC
08-19-2014, 08:03 AM
1999 34' Excella
Hillsboro
Probably better to accompany your AS below frost line.
If not an option, wrapping "may" work and not scratch the surface. But you will still have underside open to elements.
However, if they can totally cocoon then you may have something. This would mean a layer on the ground, roll AS into place, then wrap top to bottom. It just might work.
All water and batteries removed. Antifreeze includes water. So all lines must be blown clear. The "holding" tanks will need to be empty and dry. The P-traps under each sink blown clear and refilled with food grade mineral oil.
Across the top and sides you will probably need heavy blankets like moving blankets. To dampen any movement against the skin.
It is risky but might work.
Also, you could put a substantial amount of "Dessicant" to absorb whatever moisture finds its way in.
Get some BOESHIELD spray and apply to all exposed metal like the frame and tongue. That will protect thru winter and can be washed off.
Hope you come thru unscathed!
Peace and Blessings..
Channing
WBCCI# 30676
08-19-2014, 08:11 AM
Oswego
If I were going to shrink wrap, I'd get something like pool noodles (many of them) and create stand-offs so air could circulate around the skin. Also install some of the vents available for boats, and maybe a zipper for door, in case you need to get in during the winter.
-Rich-
08-19-2014, 08:27 AM
2015 30' Classic
Calgary
, Alberta
Also, some city bylaws only permit parking an RV at residents during spring/summer months. For instance, my city allows driveway parking April-October, the other months require to use out-of-town or permitted storage facilities. With that been said, enforcement is pretty lax
The wrapping for boats makes sense where the tops are typically open to the elements...I don't see that being required for trailers.
'15 Classic
'16 Ram 2500HD CTD 4x4 Limited w/ Air and Ramboxes
Instagram: cory_can
08-19-2014, 08:48 AM
2003 22' International CCD
Kiln
, Mississippi
I placed the precast concrete 18x18 inch squares you can get from the home stores to make walkways with under each tire. I also places the smaller 12x12 ones under the level jack and each stabilizer - if you're going to have those down. I like to set mine up as if I'm camping so that when the hard freeze comes I can operate everything and keep it safe. I also have a 30 amp RV plug installed on my garage within reach for shore power. Keeps the battery alive too. Keep the propane tanks full to heat her if it's real bad. Flush the water lines REAL GOOD with air and back fill with the anti-freeze that is non-toxic and made for the water lines - I don't use the anti-freeze, it tastes bad. Add RV anti-freeze to the freshwater tank - even if you drain it. A touch of bleach for sanitation too. Add RV anti-freeze to the grey and black tanks and to each trap in the sinks and shower. Lastly, a dab to the toilet bowl to ensure the moving parts don't freeze up.
Just be ready to power her up when it get real cold. My halogen lights keep her toasty down to the 20's anyway - your just looking to keep the inside above 32.
OPEN ALL THE CABINETS up to increase air circulation behind them and to the plumbing. Run the water pump with anit-freeze in the lines and EMPTY the water heater. Bathroom door open too. I have a small space heater inside vice the ac unit or propane heater - I like the option of having that build up run time vice my AS equipment.
Whew, sounds like alot - takes about an hour. Nothing on the ground for me, nothing on the outside skin but a fresh wash and a winter time prep waxing.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
08-19-2014, 09:18 AM
Superior
Those big wraps would make me worry about moisture being trapped inside. I'd build the cow catcher you describe. Maybe bolt it to the hitch somehow?
08-19-2014, 09:45 AM
Holly Lake Ranch
When blowing the lines, make sure you hold the flush valve on the toilet open to let the air go through there, otherwise the water will sit in there and you will have water all over the floor the first time you turn the city water on in the spring. The crack it causes in the flush valve is almost imperceptible but will put a bunch of water on the floor in a hurry. But the upside is that I have gotten real good at replacing flush valves, but hopefully two is enough.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
08-19-2014, 10:20 AM
Kiln
, Mississippi
I have found that you need to blow the lines 2 or 3 times over a short period of time - say a day. After one purge the lines seem to let what little moisture remaining settle and collect in the lines in low spots then need to be blown out again to clear..
Yes, blowing out the lines is a two person task. One operating the air input and one walking around activating all the valves inside including the water pump.
08-19-2014, 10:22 AM
1999 30' Excella 1000
small town
, Maryland
I thought I was bad asking people if they done their Christmas shopping in July. Kidding aside theirs talk about a polar vortex this fall. I hope it stays a rumor.
08-19-2014, 10:36 AM
Ottawa
, ON
I'm surprised that nobody has mentioned how important it is to make a list of "to-dos" for winterizing. It usually makes it into this posting subject, and I must stress how important it is to make the list and then follow it.
Don't ask how I know.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
08-20-2014, 07:14 PM
Watertown
, Massachusetts
Wow!
Oh my! That does sound like a lot of work. But thank you for all the good information.
I talked to my zoning department a day or two ago. They don't allow parking on the grass. We are going to have to put in a driveway for the AS before winter. They also don't allow a driveway skirt longer than 22', so our additional driveway will need to be at an angle off one of the existing parking spaces. Actually, that will make it easier to park.
A couple of things I still don't understand:
Why do you have to put something under the wheels and jacks if you are on a paved (asphalt or cement) driveway?
And, I was under the impression that if you properly blow out everything, remove the batteries, etc., that you can let it freeze for the winter. No? Do you really need to heat it to 32+ all winter?? Where we will be parking it we can easily run the chord to an outlet inside the house, but is that necessary?
Those little roof fans bother me. Do they really survive the winter freeze and heavy snow? They just look like little clear plastic lids. Or should we get covers for them? What about the ceiling air conditioner?
08-20-2014, 09:52 PM
1999 34' Excella
Hillsboro
They sell drawstring Covers for AC.
If you are SURE everything is dry.... No worries. If you put in antifreeze be prepared for extended flush... But no damage
Anyway.. It will be good.
Channing
WBCCI# 30676
08-21-2014, 11:51 AM
Kiln
, Mississippi
Hard freezes are hard on alot of things - even things that don't retain water. I try to keep mine above 32 during very cold spells for safety.
08-22-2014, 07:13 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
We live a little south of Mass. but cold enough to warrant a full winterization. I attach an air fitting to the city water inlet and plug my compressor in. I limit the pressure to
45-50 lbs and let it run. I go around a few times and open each water point to include the external faucet and tank flush if equipped. I do this a couple of times over about a 20 minute period. If you have a drinking water filter you should have already removed it. I have a whole house filter that I remove and re-attach the empty housing. The hot water tank is also drained and left open. Don't forget the low point drains too. Once all the water is blown out I go around and put a cup or so of RV antifreeze into each trap and the toilet bowl to keep the seals lubricated. That's it. One person job and only take a few minutes. Regarding the rooftop vents I close them to keep snow out and have never had any problem. Just don't try to open them if they have snow on top. We have been going south for the past few winters. At some point I may, or may not, put water into the fresh tank before we leave. That depends on the weather at the time. I DO NOT pump water through the trailer until we are south of a potential freeze threat. I have never had a problem with this and we are going on 9 years. If you have a filter built into any of the faucets get extras to have on hand. I remove them after blowing things out and put a new one in when things are going to be used again. Same with the whole house filter.
That's pretty much it. Last Feb. I had to snowblow a path to get it out for our flight south. They look pretty kool all covered in snow.
Enjoy your trailer and even more, Enjoy your travels with it. This ain't rocked science
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
08-22-2014, 08:43 PM
Watertown
, Massachusetts
Details - appreciated!
Thank you Polarlyse! I especially like the specific instructions - like how much pressure to have on the compressor. I guess we'll get through it. The first time is always the hardest.
We had a summer camp for some years, and one year made the mistake of not draining the pump head. I'm assuming that with an air compressor that won't happen. The winterizing on the camp was all gravity draining.
