Old 11-18-2018, 11:20 AM   #1
2015 16' Sport
Portland , Oregon
Winter storage battery charging
New to airstream family. 2015 16' Bambi. Concerning the master on/off switch (not the breaker), will the batteries trickle charge with the switch in the off position with the trailer plugged in. Gordon
insleeg is offline   Reply With Quote
Old 11-18-2018, 12:54 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes...are you able to ck the AS regularly?
I would recommend only plugging in when the batteries need it...Just MO. 😂👍
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-18-2018, 01:04 PM   #3
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
If you are referring to the use/store switch, the batteries will NOT charge with the switch in the store position. However, the batteries will continue to discharge with the switch in the store position as the switch will not turn off current to your propane detector, and maybe a few other things depending on how they did your wiring at the factory the day they built your trailer.
Mike
2015 27ft FC FB
WBCCI #3960
Caffeinated is offline   Reply With Quote
Old 11-19-2018, 10:05 AM   #4
2015 16' Sport
Portland , Oregon
Mike
Airstream NW said that it would charge either way, no matter what position it's in. They also told me I could leave it plugged in all the time. I tend to believe you. Thanks for the info. They have informed me incorrectly in the past.
Old 11-19-2018, 11:01 AM   #5
No consistency 👎
This is us...
Battery switch... on
Use/store...store mode/off
We are charging when on shore power in store mode.
ID:	328162   Click image for larger version
Amanamus
"Tahawus"
Old 11-19-2018, 11:24 AM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
we removed the BB Lion Battery inside for the winter
we place the original Lead acid one back in .
that is so i can do some winter work inside
waninae39 is offline   Reply With Quote
Old 11-19-2018, 11:33 AM   #7
Why?
Cold won't damage them.
Amanamus
"Tahawus"
Old 11-21-2018, 06:33 AM   #8
Obviously-NOT
james.mileur's Avatar
Kalispell , Montana
If you store where can leave plugged in, disconnect both black cables, connect a small battery Tender, temp compensated, plugged inside, cable snaked through cable hole in floor, plug in a few Pest Sonic zappers inside. Then all AC/DC loads work when you visit, batteries stay charged and freeze protected, and you are ready to tow with two battery terminal connections.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
james.mileur is offline   Reply With Quote
Old 11-21-2018, 07:43 AM   #9
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
can you show a picture of the back of the switches..?? on my 05 classic i only have one switch which turns off power to the buss bar except the LP det. which i remove the 1 amp fuse when I store during summer to prevent battery drain.
In winter i remove the batteries and put in garage where i can put a trickle charge on them as needed..
if you have a solar system and you park in area with sun, no need to remove the batteries as they get charge or floated every day the sun shines.
one word of caution on keeping the unit plugged in on shore power for LONG periods.. If you do not have a 3 or better 4 stage charger that might not be a good idea.
most all AS before 2018? have a single stage charger that can cook your batteries ruining them over time. (most of them are set at 13.6/7 v which is too high for long term use.. most batteries manf say 13.5 for long term float. )
https://www.trojanbattery.com/tech-s...y-maintenance/
Originally Posted by ROBERT CROSS View Post
This is us...
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 11-21-2018, 08:59 AM   #10
....snip "can you show a picture of the back of the switches..??"
The switch on the right is the use/store.
Left, battery disconnect.
The two red wires with the black insolation come directly from the Classic's two batteries, then up to the pos buss bar.
Neg buss is located on the left side.
Amanamus
"Tahawus"
Winter Battery Charging bickp Our Community 4 11-20-2018 04:18 PM
Battery charging when in storage questions. Hans627 Electrical - Systems, Generators, Batteries & Solar 23 06-30-2017 02:04 PM
Newbie Question About Battery Charging Time and Storage jackvosney Batteries, Univolts, Converters & Inverters 0 02-01-2017 11:54 AM
Winter storage battery charging. obsail 2016 - Current International 29 11-30-2016 01:55 PM
Battery Charging During Winter John and Anne General Motorhome Topics 8 02-29-2004 08:58 AM
