Old 11-15-2014, 01:15 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
White hose protruding from under the
One quick question on winterizing our 2012 FB Flying Cloud.
There is a small hose protruding from under the AS by the back access door. I believe I had closed the handle on the pipe on the inside of the access door and when I was adding antifreeze I notice the antifreeze coming out of it. Is that suppose to happen? It did not when I turnt the small the handle the other way on the pipe that is inside the access door.
Also do you leave the fresh water drain open or closed for the winter?
John
urnmor is offline   Reply With Quote
Old 11-15-2014, 01:21 PM   #2
dznf0g's Avatar
Oswego , Illinois
Don't know about your hose end and leaky AF. Nothing on mine like that. I leave may fresh tank drain open in winter.
-Rich-
Old 11-15-2014, 01:24 PM   #3
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Air conditioner drain tube?? Can't think of any other small white tubes.
Freshwater tank drain, I leave open.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-15-2014, 01:31 PM   #4
urnmor's Avatar
Berlin , Maryland
If it is the AC drain and I think it is why would antifreeze becoming out of it? When I turnt the vale inside the access department it stop draining.
Old 11-15-2014, 01:34 PM   #5
TinTin's Avatar
Canmore , Alberta
Shouldn't be AF for sure if it is A/C drain ... perplexing.
Bob and Nancy
Old 11-15-2014, 01:35 PM   #6
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
That drains the part of the piping that the low point drains cannot drain; the valve is in the storage locker. I asked Airstream about that when I bought my 25 FB.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-15-2014, 01:44 PM   #7
2013 20' Flying Cloud
Between Here and There and Nowhere , what have you got?
Your low-point drain is open...turn the valve handle the other way, I think clockwise
openroad118 is offline   Reply With Quote
Old 11-15-2014, 01:57 PM   #8
TinTin's Avatar
Canmore , Alberta
Larry
Solved. Well done Larry.
Bob and Nancy
Old 11-15-2014, 02:22 PM   #9
urnmor's Avatar
Berlin , Maryland
My thanks to all for their assistance. The value is closed and the antifreeze has been added. Now if I take it out in the winter it will truly be dry camping.
Under Vinyl stripe, white stain removal? brianbraun Cleaning, Stripping & Polishing 0 03-20-2013 11:36 AM
Installing an under belly sewer hose holder Lumatic Belly Pans & Banana Wraps 1 06-21-2010 05:48 PM
Is furnace duct hose the same as household dryer duct hose? Bearstream1 Furnaces, Heaters, Fireplaces & Air Conditioning 4 01-12-2009 10:21 PM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
