Old 12-18-2008, 03:27 PM   #1
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
Where's the hot water heater switch??
64 Globetrotter. So I've been hunting for the hot water switch before I drain the tank for winter. I just can't seam to find it. I have the AC on for now as I'm doing a little work inside, so I have a space heater keeping it off freezing, But soon it will go off for the winter. Maybe I'm just blind or stupid or both
man7sell is offline   Reply With Quote
Old 12-18-2008, 03:35 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
A switch? Our 67 doesn't have a switch. You just shut down the fire, turn the by-pass valve(s), and then drain it by taking out the lower plug.
Lynn
WBCCI 21043
Old 12-18-2008, 03:53 PM   #3
Kevin245's Avatar
I presume you have a LP/Electirc water heater?
The electric on/off switch on mine is on the backside. It looks like a small light switch I just open the cabinet and flip it off. Just follow the wires if you're not sure.
If it's LP your talking about it's the small knob that's part of the gas valve body. When you open the outer door, it's usually on the left side.
Hope this helps...Wish I had pictures.
Eleanor Roosevelt
Old 12-18-2008, 04:20 PM   #4
man7sell's Avatar
1969 27' Overlander
Lynn
Thanks Lynn, then I will install a circuit breaker.
Old 12-18-2008, 04:22 PM   #5
man7sell's Avatar
1969 27' Overlander
I'll check that too. The LP has had a PO mod that's on a switch
Old 12-18-2008, 08:08 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If it's a "hot" water heater switch, then maybe it's drawing too much current. If it's merely a water heater switch, like many are, then just turn it off.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Electrical & Hot Water Switch woodedareas General Interior Topics 6 08-17-2008 06:47 AM
Hot water heater. mrmossyone Water Heaters, Filters & Pumps 8 12-23-2007 02:26 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Hot water heater Action Water Heaters, Filters & Pumps 25 07-21-2006 06:37 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
