11-03-2012, 02:24 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
Where Is The Anti Freeze Going
Okay, I've bypassed the water heater (checked the manual). And as a preliminary, I blew everything out with compressed air.
By the way I did this winterizing operation successfully last year.
Unscrewed the intake of the water pump and replaced with the 3 foot hose to siphon the antifreeze.
Now I've pumped 2 gallons into the system with a trickle coming into the the lavatory sink.
All tanks checked to be empty; black, gray, water heater bypassed, low point drains, and gray/black valves opened.
I camped last weekend and no leaks. So far no freezing temps.
My question is, where in the heck is the antifreeze, and why isn't it coming out the fixtures like it should.
Now I'm off to the parts store to get more antifreeze, and hopefully someone with help turn on my dim light bulb by the time I get back.
11-03-2012, 03:17 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"Unscrewed the intake of the water pump and replaced with the 3 foot hose to siphon the antifreeze.
Now I've pumped 2 gallons into the system with a trickle coming into the the lavatory sink."
Murrey,
Did the pump stop running when pressurizing with the A-freeze? (before opening the faucets)
2016 30' Classic
Hinckley
, Ohio
Drain open? You have a few on your trailer.
11-03-2012, 03:57 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Do you mean the low point drains are open or are they closed? Do you have to fill the fresh water tank from outside or is there valving to fill it while connected to city water? If not those, I would check the WH again to see that it is bypassed.
11-03-2012, 03:58 PM
1974 Argosy 20
Kooskia
, Idaho
Sometimes the water heater by pass valves don't shut the water off to the water heater if they are internally kaput. I have had that happen.
Open the water heater drain and see if anti freeze comes out. If so, you know where it is going.
11-03-2012, 03:59 PM
1993 34' Excella
Estancia
, New Mexico
Double check your by pass. Without a bypass you will pump in 6+ gallons
11-03-2012, 04:01 PM
2007 23' International CCD
Lapeer
, Michigan
If the drains underneath the Airstream aren't closed it is going out onto the ground. Are you on pavement? Mine emptied onto the Wal -Mart parking lot which was quite apparent, then I closed them and bought more antifreeze and all was well before heading North. With the hot water heater bypass a couple of gallons should do you.
11-03-2012, 04:25 PM
Branson
, Missouri
Just call me dumas! And that's not the Three Musketeer variety.
Bill M. and wheel interested BOTH get the dumas's booby prize.
THE LOW POINT DRAIN BALL COCKS WERE OPEN.
Well, at least I know the gravel under the trailer isn't going to freeze any time soon as it has 3 gallons of the pink stuff on it!
Seriously, I appreciate all of your suggestions!
11-04-2012, 05:48 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
murrey,
Don't feel bad....
Brain Farts and Airstream's go together.
Two Seasons ago.
Left the streetside rear low P drain partially open, pump not shutting off, shut pump off, run around trailer ck all, nutt'n much, turn pump back on, drip, drip, drip.
11-04-2012, 06:31 AM
Branson
, Missouri
Originally Posted by ROBERT CROSS
murrey,
Don't feel bad....
Two Seasons ago.
LOL!
For me, it's oldfartitous, I guess. ;-)
Murrey
11-04-2012, 08:38 AM
Pittsfield
, Maine
Why open the low point drains? Bypassing the water heater, blowing the lines, draining the tanks, and adding anti-freeze should take care of the low point lines as well. Nine winters at -15 deg with our current Airstream and never a problem. The only reason I can see for opening the low point drains would be to make a desperate attempt at winterizing without using anti-freeze. Not something I would want to try here in Maine!
Cracker
11-04-2012, 08:45 AM
1993 34' Excella
Estancia
, New Mexico
You need to open the low point drain to drain the fresh water tank , at least in mine. If you don't open those valves they may seize over time. Why dilute the anti freeze with water in the system.
11-04-2012, 09:01 AM
Port Orchard
I hope you open the low point drains when blowing out the pipes.
Assuming that you do, they should be the last to be closed (because they are the low point and water is heavier than air). I can see why it would be easy to forget to close them. I don't know whether RV antifreeze is heavier, lighter or the same weight as water. However I would not want to rely on chance to ensure that the antifreeze is thoroughly mixed with whatever water remained in the pipes leading to the low point drains, if they had not been opened and flushed.
Personally, I don't use antifreeze except in the waste system. I blow out each individual line by opening each faucet individually (including the low point drains), until not even a vapor can be seen leaving the faucet. I've been doing that for several years without a problem. -15 is not an unusual temperature here.
Ken
11-04-2012, 10:24 AM
1972 31' Sovereign
Lexington
After pumping multiple gallons into the system this fall, Chris figured out that it was all going to the water heater since he apparently installed the bypass backwards. It was easier time-wise this fall to just fill the water heater. He'll fix it in the spring.
Kay
11-04-2012, 10:29 AM
Port Orchard
Kay
I would think, in the spring, you could save the antifreeze as you drain it and use it again. you'll have plenty.
Ken
11-06-2012, 05:21 PM
1972 31' Sovereign
Lexington
Yah, no kidding! I really have no idea if used antifreeze is good to use again.... I suspect Chris will say no. I suspect that with the entire water system at risk, I will say no too. We spent more than enough time on it the first time around - don't necessarily want to do it again!
Yup, as I suspected, he said no.
Kay
11-06-2012, 05:48 PM
1993 34' Excella
Estancia
, New Mexico
Kay
Before I put in my bypass I used to flush the system with antifreeze drain it off and reuse it next season. No problems except it gets a little stinky.
Now with my bypass it only takes me a gallon so why bother.
