Old 11-04-2012, 10:29 AM   #15
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by Minno View Post
After pumping multiple gallons into the system this fall, Chris figured out that it was all going to the water heater since he apparently installed the bypass backwards. It was easier time-wise this fall to just fill the water heater. He'll fix it in the spring.
Kay
I would think, in the spring, you could save the antifreeze as you drain it and use it again. you'll have plenty.
Ken
Old 11-06-2012, 05:21 PM   #16
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yah, no kidding! I really have no idea if used antifreeze is good to use again.... I suspect Chris will say no. I suspect that with the entire water system at risk, I will say no too. We spent more than enough time on it the first time around - don't necessarily want to do it again!
Yup, as I suspected, he said no.
Kay
Old 11-06-2012, 05:48 PM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Kay
Before I put in my bypass I used to flush the system with antifreeze drain it off and reuse it next season. No problems except it gets a little stinky.
Now with my bypass it only takes me a gallon so why bother.
Lumatic is online now   Reply With Quote
