Old 01-05-2019, 09:26 PM   #1
2007 25' Safari FB SE
Detroit , Michigan
Where are my low point drains?
Good evening, everyone.
I've been an avid learner for the past 18 months and just got our first Airstream: a 2007 Safari FB from the original owner.
In winterizing, I've completed blowing all the lines clear but can't find the low point drains anywhere. Reading the forums, it seems they're typically located street side, aft of the tires. But I only have my gas line there down there (see pic). Anywhere else I should be checking?
Zayd
zayd is offline   Reply With Quote
Old 01-05-2019, 09:40 PM   #2
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Zayd
Congrats on the trailer. We wish you much happy camping and safe travels.
What size and floor plan do you have? On our 2013 25FB, the fresh tank drain and the main hot and cold low point drains are on the street side, hidden by the tires. I can see them when I look between the tires and crane my neck around. There is also an additional cold low point drain near the water heater. The valve for that is inside the outside storage compartment on the curb side (we have twins, queen models may differ).
Good luck finding your drain.
SSquared is offline   Reply With Quote
Old 01-05-2019, 10:27 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
There are 3 drains in the black plastic box (the tank cover) that hangs beneath the trailer. Two brass petcocks are in depressions in the bottom surface of the box. The fresh water drain (a white plastic faucet) is on the curb side of the box between or behind the tires.
There will be one or two other low point drains (my Safari has only one) somewhere in the plumbing. Look beneath the metal belly pan to find a pipe (or 2 or 3) extending an inch or two below to the exterior. There will be a stop valve somewhere above on the interior of the trailer. (There is also a drip pipe for defrosting beneath the refrigerator that is not related to plumbing)
Don't for get the exterior shower if you have one. Also the sprayer at the sink.
edit:
I found the owners manual for your trailer. It says: "The 25 foot front bed, 28 foot rear bed and the 27 foot front bed has exterior water line drain valves. If you look between your tires you can see a “box” that is a few inches lower than the trailer frame. This “box” or tank pan supports the water tank. The line drains will be the two brass pet cocks extending from the bottom of the pan. The white plastic petcock located on the same pan is to drain the water tank"
you can download a copy here:
https://www.airstream.com/owners/man...r/2007/page/2/
Look in section F.
Alan
Old 01-06-2019, 02:24 PM   #4
Detroit , Michigan
Thank you for the welcome and helpful information, gentlemen.
I've attached a pic of what I see in that area. I see the two petcocks, but they looked like they were directly in the fresh tank. Reading Alan's excerpt from the manual, I see that's just a tank cover. So I assume that hot/cold lines run underneath that cover and terminate in those low point drains. I'll drain those and that should be the end of it. The rest of the trailer is done.
And I'll be starting a new thread on today's unfortunate moisture discovery...
Thank you again.
Old 01-07-2019, 02:34 PM   #5
greenflag's Avatar
2016 30' International
Quartz Hill , California
I had a 2007 International with rear bedroom. The brass petcocks are the low point drains I believe. The white plastic petcock is the freshwater drain. Living in So CAl I never had to worry about winterizing much.
greenflag is offline   Reply With Quote
Old 01-07-2019, 02:54 PM   #6
Long Island , New York
. . . Reading Alan's excerpt from the manual . . .
Welcome to the forum!
When you got this trailer, was it missing the owner's manual? You should have one, and should read it thoroughly at some point. Alan's post has a link to see your manual online, which you can print out. You should also be able to order a copy someplace. Airstream has changed its website recently, so if you don't have any luck finding a manual to print or order, please let us know.
My guess is that you have more than 2 low point drains [just one cold and one hot?]. Have you drained the water heater, water pump incl. its pre-filter?
The topic of winterization can be nuanced, depending on your model. Here is the basic Winterization sticky thread in this sub-forum FYI:
http://www.airforums.com/forums/f458...rize-7222.html
Have fun with the new AS!
Peter
PS -- Using Alan's link, and the blue Download link, the plumbing Section F starts on p. 68/103 of the PDF, which you can save to your computer. On PDF p. 70/103 it says: "The 25 foot front bed model has an access door on the bed top." Have you found this access door on the bed top? There may be low-point drains in there IMO. This same section has the text which Alan quoted about the two external drains. The manual also describes the location of your water pump. Have you located the pump, and followed the winterization process for the pump? I would advise having a hard copy of the manual, and locating every single plumbing item, to familiarize yourself with the trailer. The manuals can be notoriously incomplete or even inaccurate FYI. Nothing like a hands-on full-scale review of everything IMO.
"Measure Twice, Cut Once" as they say in construction!
OTRA15 is online now   Reply With Quote
30' International CCD low point drains? LivLoveLaugh 2011 - 2015 International 5 04-19-2013 08:12 PM
Low point drains in 2012 Mike and Gloria 2011 - 2015 Classic (all lengths) 3 03-18-2013 10:04 AM
2010 27FB Low Point Drains PJohnson Winterizing, Storage, Carports & Covers 2 10-31-2010 01:17 PM
front low point drains, 19' int'l ericwarren Winterizing, Storage, Carports & Covers 3 12-18-2008 03:58 PM
Low point drains runningbarre Winterizing, Storage, Carports & Covers 5 09-25-2008 07:07 AM
