Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Prev Previous Post   Next Post Next
Old 03-24-2009, 09:33 PM   #1
Profile:  McLean , Virginia
When to turn on heat???
Hello at what temperature do I need to turn the furnace on? Does the occasional cold night where the temperature hovers at 32 warrant rushing over to my parents house to turn on the furnace?
What about say 28 degrees for 6 or so hours .....I guess my question is how cold for how long is troublesome? It does not seem practical to to do a full winterization for the occasional cold night. Just worried about when I should be worried
tmarquis is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 37 07-16-2009 10:08 PM
Turn The Key And Nothing Happens Chaplain Kent Mechanics Corner - Engines, Transmission & More... 102 04-20-2009 08:02 AM
The PO was going to turn it into a shed! kenthelen Member Introductions 9 07-18-2008 10:57 PM
How to turn off Dometic refer? Vinoblanco Refrigerators 1 04-03-2006 11:34 AM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 03:08 PM
