Old 10-25-2008, 10:42 AM   #1
2006 19' International CCD
Philadelphia , Pennsylvania
Wheels while in storage
Hello All,
curious what you do with your wheels while in storage.
do you cover them?
do you remove some air pressure?
do you put it on wood vs the pavement?
thanks!
ericwarren is offline   Reply With Quote
Old 10-25-2008, 11:03 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
What period of storage are you considering, weeks, months, or years.
If a long period I would be more concerned with the axles than the wheels. Hinchen axles don't like to remain at rest. The rubber takes a set. If you are storing or parked on site for a longer period of time I would jack the trailer up enough to take most of the load off the axles.
2004 Excursion 4x4
Old 10-25-2008, 11:27 AM   #3
thanks howie.
just a few months for the winter...
Old 10-25-2008, 11:32 AM   #4
1973 31' Excella 500
Morristown , Tennessee
I agree that if you are not rolling for an extended period - several weeks - I jack up the trailer to relieve the load. Any longer, I remove the wheels with tires and store them inside to keep dry and out of the sunlight. Good luck.
Joe
Alumin8 is offline   Reply With Quote
Old 10-25-2008, 02:07 PM   #5
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
This is us....
Name:	2007 WINTERIZE 009.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-02-2010, 09:56 AM   #6
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Axles and storage?
I jack up the trailer on my 30' and use a cement block with 2x6's on top to shim to the bottom of the frame on each side. This takes the weight off the tires and axles. This allows me to do my axle lubing in the spring, checking brakes and elect./hydraulic operation before and drop and roll.
Good luck and see you on the ROAD!
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Looking for wheels! chuman70 Wheels, Hubs & Bearings 6 04-07-2008 08:32 PM
new wheels evelitalian Wheels, Hubs & Bearings 7 03-07-2008 03:13 PM
New Wheels TN-TUNDRA Wheels, Hubs & Bearings 11 12-20-2007 08:24 PM
wheels the same? dmaiden Wheels, Hubs & Bearings 5 10-10-2006 08:15 PM
New wheels for a '92? casarodante Wheels, Hubs & Bearings 5 06-06-2006 11:23 AM
