Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 08-28-2019, 07:37 AM   #1
2017 27' Flying Cloud
London , Ontario
What is this black valve?
I am (sadly) winterizing my trailer today. I know the top valve (green) is the winterizing bypass valve, but what is the black one (red)? Is this one involved in winterizing?
If not, what is the appropriate normal position for this valve when using the trailer, and what purpose is this valve? Thanks for any help!
27FB 2017 Flying Cloud
F-150 Lariat
Ham Radio Callsign - VA3PGJ
Philip Jones is offline   Reply With Quote
Old 08-28-2019, 10:13 AM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I believe that is a low point drain.
sheriff1 is offline   Reply With Quote
Old 08-28-2019, 10:27 AM   #3
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Low point drain.
Keep it closed when the Airstream is in use.
Open it when draining water from the lines.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 08-28-2019, 02:11 PM   #4
London , Ontario
Thank you! So, this low point drain drains low-lying water in the water heater to the low point drains on the outside of the rig?
I presume the closed position is when the notch is 90 degrees from the direction of water flow?
F-150 Lariat
Old 08-28-2019, 02:28 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
You may find it’s a water heater low point drain that empties directly underneath the valve - that’s the case with mine (2012 27FB). I found it first season after it was winterized. I’m filling things up and trying to get city water to fill the water heater and there’s a massive flood outside under the water heater. Turned that knob to close it and all was good.
Old 08-28-2019, 06:37 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Just to throw a wrench into the pot here. Follow the pex line and see where it
comes from / goes to. I found an in-line valve on mine that served the toilet supply line. Something we can turn off if I need to remove or service the throne. If it has an outlet that drains through the floor then more likely to be a low point drain.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 23 11-04-2022 06:48 PM
Valve or no valve 59as LP Gas, Piping, Tanks & Regulators 2 10-18-2014 06:36 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
