Old 10-08-2019, 07:32 PM   #1
2016 25' Flying Cloud
Vadnais Heights , Minnesota
What is this and what needs to happen with it for winterizing?
Gonna winterize soon with both compressed air and Rv antifreeze.
Read a ton of posts here and feel good about what to do....except for this pipe behind the toilet . I know I need to hold open the flush valve in the toilet when blowing air through the system and be sure antifreeze goes through the toilet flush ....
This valve is probably something obvious and I should know about it but I donít .
Can someone tell me what position it should be in, When and why?
Thanks !
Fipp is offline   Reply With Quote
Old 10-08-2019, 08:09 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
That is the toilet water supply cut off valve. Do nothing to it. Go ahead with air and antifreeze as planned...The way it is now is open. If you turn the handle perpendicular to the line, it would be closed and stop water flow
CRH is online now   Reply With Quote
Old 10-08-2019, 08:17 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
That valve controls the water flow to the toilet flush mechanism. It is currently in the open (ON) position. When the handle is 90 degrees to the pipe it is closed.
Leave it in the open position (as is) when you apply air pressure and flush the toilet to clear that section of water pipe and the valve of moisture.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 10-08-2019, 10:48 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you put antifreeze in the system properly, you will fill these lines and have little chance of freeze.
Blowing out the lines.. totally drying is possible.. and when you open the toilet valve (fill to flush), you will have confidence all is good.
The toilet plumbing typically is where you will see freeze.. so, draining well is important.
don't hesitate asking your questions!
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-09-2019, 05:11 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
If your toilet has the spray nozzle wand, don't forget to spray it out too.
And the shower head/hose.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-09-2019, 09:12 AM   #6
1976 31' Excella 500
Chappell Hill , Texas
Why use antifreeze if you will use air to blow the water out of the lines? Seems like an unnecessary step since there won't be enough water left to cause damage if it freezes.Not to mention having to flush the antifreeze out.
Once I blow my lines out, I just close all the valves till i'm ready to use again.
tbashin is offline   Reply With Quote
Old 10-09-2019, 09:14 AM   #7
Thumbs up
I have the DW hold the toilet pedal down to open the valve as I blow lines out. Spray hose same procedure. Never had a toilet area freeze since I learned to do this.
Old 10-09-2019, 09:39 AM   #8
1996 30' Limited
Maryville , Tennessee
On winterizing and blowing the water out of the system be sure you pump all the water out of your water pump. When you blow the system it may bypass the water pump and you can crack the water pump if there is water left in the system. Antifreeze is usually run through the pump so this will take care of that issue.
earljones458 is offline   Reply With Quote
Old 10-09-2019, 10:05 AM   #9
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I concur
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
https://www.facebook.com/groups/2284022111820203/
cazual6 is offline   Reply With Quote
Old 10-09-2019, 10:31 AM   #10
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Blow the lines and anti--freeze via the pump (not from the fresh water tank - YUCK) don't forget the toilet sprayer and outside shower!!!
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Old 10-09-2019, 12:08 PM   #11
2008 20' Safari SE
Ranchos de Taos , New Mexico
When discussing and advising about winterizing, one should take into consideration the climate where the Airstream (or whatever) lives. Texas and Minnesota are very different. When we moved from a southern state that experienced few deep freezes to the mountains in a western state, we changed our winterizing routine.
SafariSarah is offline   Reply With Quote
Old 10-09-2019, 05:42 PM   #12
CruizinDux's Avatar
Tracktown USA , Oregon
....and the BW flush line. JC uses a very cheap BW back flow/ck valve part that cracks it you look at it cross eyed. I only use air to winterize, but apparently missed some moisture when doing a quick winterize OTR. In the 20's most have removed the dinette to gain access. I cut thru the side of the bath vanity and replaced it with brass. Usually not found in a convenient location.
CruizinDux is offline   Reply With Quote
Old 10-10-2019, 06:17 AM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Using antifreeze will make sure you displace and residual water left in the pipes. Unless you apply enough pressure and dry out those lines, any droplets left in the system can move to a low spot in a particular line and freeze and crack it. It’s just not worth taking the chance. I sanitize my water system every spring and that alone will remove any traces of antifreeze. The antifreeze brands I use are environmentally friendly pet and animal safe.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 10-10-2019, 08:37 AM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
In our climate, antifreeze is the best option for ensuring no winterizing issues. We replaced a water pump after using air only. Now we do both.
Kay
Old 10-10-2019, 11:39 AM   #15
Long Island , New York
You appear to have received your answer to leave the valve alone [open] and winterize as you wish.
Any chance that this thread could avoid de-volving into another AF-or-not [many-times-repeated] discussion?
https://www.google.com/search?q=anti...com&gws_rd=ssl
[dozens of earlier threads with hundreds of posts on-topic]
Sticky topic at the top of this forum -- over 400 posts on-topic: http://www.airforums.com/forums/f458...rize-7222.html
Thank you for your consideration,
Peter
PS -- Photo in Post #1 -- it does not get much simpler than this IMO:
Old 10-10-2019, 11:45 AM   #16
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Leaving the antifreeze in will ensure that all the plumbing joints and the toilet seal will not dry up over the winter and potentially leak come spring. It is also important to put antifreeze in all the p-traps to make sure they don't freeze and keep tank odors from coming into the trailer.
thewarden is offline   Reply With Quote
Old 10-10-2019, 02:01 PM   #17
Peter
I asked and many kindly responded and yes I have my answer. What is it you expect me to do about helpful comments offered from nice people?
Old 10-14-2019, 02:18 PM   #18
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Originally Posted by jcanavera View Post
Using antifreeze will make sure you displace and residual water left in the pipes. Unless you apply enough pressure and dry out those lines, any droplets left in the system can move to a low spot in a particular line and freeze and crack it. Itís just not worth taking the chance. I sanitize my water system every spring and that alone will remove any traces of antifreeze. The antifreeze brands I use are environmentally friendly pet and animal safe.
Jack
On the mark !!!
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 10-16-2019, 11:11 AM   #19
2019 22' Sport
Raleigh , NC
Question.
Has anyone used wiper fluid in place of antifreeze? We live in NC and it rarely gets super cold.. antifreeze cold.
NormanA is offline   Reply With Quote
Old 10-16-2019, 11:13 AM   #20
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by NormanA View Post
Question.
I have not and definitely wouldnít recommend it. RV antifreeze is non-toxic - windshield washer fluid isnít so human- and/or pet-friendly....
Winterizing / De-Winterizing Adventure.AS Winterizing, Storage, Carports & Covers 0 03-07-2019 09:25 AM
Newbe on first winterizing needs to know ... Rob Cope Winterizing, Storage, Carports & Covers 19 12-16-2016 09:05 AM
And let this happen to you. SaabLover Our Community 7 02-03-2007 08:37 AM
And you think it wont happen in your town! rebel beck Off Topic Forum 17 04-09-2006 05:45 PM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
