Old 09-12-2006, 01:07 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
What fittings do I need?
Ok, I am 4 hours away from my 31' 1979 International and am starting to think about winterizing it. I want to start winterizing it by blowing out the lines with my air compressor from the city water intake. My compressor has the standard quick on/off fitting at the end of the hose. What do I need to go from the quick on/off fitting on the compressor to the city water fitting on the trailer? I'm willing to make up a conversion hose as a connector between the two if needed.
wacnstac is offline   Reply With Quote
Old 09-12-2006, 01:13 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I use one of these
http://www.campingworld.com/browse/s...ug/skunum=4410
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-12-2006, 01:26 PM   #3
Images: 43
How does the air compressor hook up to that fitting?
Old 09-12-2006, 01:36 PM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
I got an air quick connect, then went over the plumbing aisle. I connected that to a stop valve, from there used a neck up nipple to a brass garden hose fitting. That way I can connect it directly to airhose and screw it into the water intake, and then use the valve to open the air into the system as needed.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 09-12-2006, 01:38 PM   #5
Images: 43
That sounds like what I'm looking for. You gotta picture of that setup?
Old 09-12-2006, 01:49 PM   #6
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Yeah, I'd like to see it too.
Family of Disney Fanatics
WBCCI# 4821
Old 09-12-2006, 02:23 PM   #7
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
I'll try tonite.
John
Old 09-14-2006, 07:35 AM   #8
Images: 43
Let me ask you this, is it a female or male fitting that the city water inlet expects? I suspect the city water connector on the trailer is female but without being at my trailer I'm not sure.
Old 09-14-2006, 08:27 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
You are correct City is female, hose male
www.balrgn.com
Old 09-14-2006, 09:52 AM   #10
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
I made the same "blow out" attachement for out 1976 Overlander. I had the "quick connect" on the end of my air hose. I took one of my "quick connect" (female ) and went to our local hardware shop, I found a male hose bib to pipe thread fitting and I think that I only needed one fitting to join the female "quick connect" to the male hose bib fitting. The best part of this arrangment is you can screw in your hose bib and then connect to your compressor and not have to hold anything. After connecting just go in your trailer and open each faucet until you have mostly air. Depending on the size of your compressor you will have some times that you might have to wait until pressure builds back up.
Sorry about a photo, but our trailer is 3 hrs away...
Good luck!
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 09-14-2006, 10:56 AM   #11
Images: 43
I got setup at Home Depot today. I now have a connector made of four parts to go from quick connect to standard male garden hose that cost me $13.
Old 09-15-2006, 07:53 AM   #12
2006 30' Safari
Orlando , Florida
Could you post a photo so I could get an idea of what I need to replicate? I have a small compressor that would probably do the job but I'm not familiar with the types of fittings available to put what you describe together.
Thanks, Tom AKA Minnie's Mate
WBCCI# 4821
Old 09-21-2006, 07:19 PM   #13
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
Originally Posted by balrgn
Thanks for the advice. I went to Camping World in Denver, and bought one today. Just what I needed, and only $2.00. I have one more trip to make at the end of next week to Arches Nat. Park, and then I'll winterizing for the first time. I think I've picked up what I need from here, and speaking to the local Airstream dealer. My biggest challange is going to be keeping the snow blown away during the winter. I've had as much as 10' in my backyard, and we get several storms with more then 3' at once.
Thanks: Charlie
Pacerized is offline   Reply With Quote
Copper compression fittings vs. flare fittings phippsto LP Gas, Piping, Tanks & Regulators 37 12-07-2015 03:08 PM
Sealant for holding tank & dump fittings? wayner1239 Waste Systems, Tanks & Totes 8 04-06-2006 06:58 PM
LP Wierdness / Where to buy copper LP pipe and fittings? nickglase LP Gas, Piping, Tanks & Regulators 19 03-11-2006 03:43 PM
Pex-Crimped vs Qwest fittings StingrayL82 Plumbing - Systems & Fixtures 15 11-02-2005 12:04 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 08:54 AM
