Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 11-29-2015, 08:43 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Water system losing air pressure while blowing out for winterization
Curious if it is normal for the water system to loose pressure while blowing out the pipes?
I was having a slow pressure loss, but chocked it up to a loose water heater drain plug I could hear leaking as I was pressurizing.
Then I went to blow out my other trailer, it wouldn't hold pressure for much time at all.
Both trailers have no water leaks and good running plumbing systems.
Ted S. is offline   Reply With Quote
Old 11-29-2015, 09:38 PM   #2
Mission , Texas
Yep ...
https://www.physicsforums.com/thread...ghness.142407/
nrgtrakr is offline   Reply With Quote
Old 11-30-2015, 06:07 AM   #3
2015 30' FB FC Bunk
Every residential water system in a new house or building is pressure tested with air, so it is confusing to me why an RV system can't hold air.
Old 11-30-2015, 06:33 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yes, it's entirely normal. When you're blowing out the pipes the idea is to have someplace for the water to go, which means the faucets should be open. An open system will not retain air. Blowing out the pipes is not a pressure test.
Old 11-30-2015, 06:44 AM   #5
2015 30' FB FC Bunk
Seems like 1/2 the people close the entire system, pressurize, then open faucets one by one, the the other 1/2 the folks leave a faucet open while blowing.
It would seam to me closing all of the faucets and pressurizing the system should result in the system holding air pressure.
If I left a faucet open, then I would expect results as you mention.
Old 11-30-2015, 07:36 AM   #6
Since I have a compressor with an air tank, I don't need to build pressure in the pipes. But if you are using a tankless compressor, you should allow pressure to build first, then open a faucet. Basically the pipes take the place of the air tank in that case.
But if you're one of those folks who build air pressure in the pipes, remember that watertight is not the same as airtight. The pipes should hold air pressure up to the rating of your built-in water pressure regulator (typically 40 or 45 psi), but if you build up more air pressure than that, you can expect air leaks.
Old 11-30-2015, 07:37 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The check valves used in the water system along with pressure relief valves could have slow air leaks but won't allow water thru. There are at least 2 check valves, one at the pump and one at the city water connection.
Old 11-30-2015, 07:43 AM   #8
2015 30' FB FC Bunk
I am building pressure only to 20-25 psi. I have a shop compressor, but I am trying to use my travel compressor so I learn how to winterize on the road.
So you guys think there are slow leaks the air can get through and not water?
I'm not sure if I am believing that just yet, we test all plumbing systems with air.
Curious from those who pressurize their systems at the blow out if they experience pressure loss.
Old 11-30-2015, 07:44 AM   #9
Mission , Texas
Water system loosing air pressure while blowing out for winterization
Again, from the link I posted above, air molecules are smaller than water molecules, so a plumbing system may not leak water, but could leak air.
Very simple ...
Old 11-30-2015, 08:15 AM   #10
2015 30' FB FC Bunk
Very simple ...
So if were talking vapor diffusion vs bulk water, then I believe you and the link.
But since every new building water distribution in the country is tested with air, which I have seen a thousand times, I do not believe it.
Very simple.
Old 11-30-2015, 08:16 AM   #11
O2 and N2 and CO2 are smaller molecules than H2O? That's news to me. It's not smaller molecules that allows air to leak from a watertight system, it's viscosity. Liquid water is more viscous than air; liquid water molecules stick together.
Not only is watertight not the same as airtight, it's not the same as steam-tight either. Water vapor can leak where liquid water can't, so it's not molecule size that makes the difference. We're talking about a plumbing system, not a permeable membrane like a reverse-osmosis water purifier. For a permeable membrane molecule size does make a difference, and water molecules are smaller.
But that's not important to the OP, only to engineers and scientists. For the OP's purposes, it's enough to know that a plumbing system that's watertight can still leak air if there's enough pressure.
Old 11-30-2015, 08:32 AM   #12
2015 30' FB FC Bunk
Protagonist
You are a mechanical engineer (even retried engineers are still engineers ) so you know we test building domestic supply with air, so from your experience, shouldn't our systems hold air?
One on the reasons why this is important to me is because it would be a good way to check for leaks as routine maintenance. Especially if I silence the pump with an isolation mount, flex hoses, etc. It just doesn't make sense I keep loosing pressure, correct?
Old 11-30-2015, 09:10 AM   #13
As I said in an earlier post, it SHOULD hold air at least up to the pressure setting of the built-in pressure regulator, which is probably set somewhere around 40 to 45 psi. Just because your system will hold water up to 45 psi— and air up to the same pressure— there's no guarantee that it will hold higher pressures.
I don't know what factor of safety Airstream uses for their freshwater systems. If it was me I'd want my 45 psi water system to be airtight to 60 psi or better, but then I'm not Jackson Center. Given the number of people whose Airstream's fresh water systems develop leaks when their pressure regulators fail, I'd say the factor of safety is closer to 1.0 than I'm comfortable with.
I'd suggest that if you use a tankless compressor for blowing out your pipes, always use one that has a built-in pressure gauge, so that you know exactly how much pressure you're putting into your system.
Old 11-30-2015, 03:03 PM   #14
2015 30' FB FC Bunk
Looks like testing RV water systems with compressed air is not uncommon, here is a good article on it. Even more interesting, looks like RV manufacturers actually do it just like in building construction.
The RV Doctor: Properly Testing RV Fresh Water System
I'm going to learn how to do it at some point.
Old 11-30-2015, 04:00 PM   #15
1973 31' Sovereign
Middletown , California
Yes, I would expect a trailer plumbing system to hold air pressure up to at least 45psi. If it doesn't I'd find out why not. I wouldn't go much over 50psi at max though and there is probably a pressure relief valve for the water heater that if it opens might be hard to get it to re-seat. Leland
ijustlee is offline   Reply With Quote
Old 11-30-2015, 04:30 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I am not aware of a household plumbing system that has the cheap plastic check valves like those in a travel trailer.
It would be interesting to take a survey and ask this question.
Turn on the pump in the coach. With all fixtures turned off. Let the pump build pressure and shut down. Then shut the pump off. Wait 12 hours then without turning any fixtures on, turn the pump on.
How many pumps start and run if only for a second or so?
How many pumps run for 10 seconds or so?
I am somewhat confused as to why one would try to blow out the systems without opening at least one valve at a time. I usually start by opening the valve closest to the pump until air comes out. Then close that valve and open the next one down stream. Repeat until all systems are purged with air. Then pump in the anti freeze.
Old 11-30-2015, 04:44 PM   #17
mapleton , Utah
I'm certainly not a plumber but I would have to agree with the posters who believe that your system should hold air to the lowest designed pressure point- probably the relief valves. No system will hold pressure forever but I would be looking for the air leakage if it doesn't hold minimal PSI for a reasonable amount of time.
I will be very disappointed if my system doesn't hold pressure when I test it, but then I am building from scratch and not dealing with factory installed plastic components.
tim
rumrunner is offline   Reply With Quote
Old 11-30-2015, 05:20 PM   #18
If you're using a tankless air compressor, the only practical way to build up enough pressure is to air up the system with all faucets/valves closed, then open one valve to blow out water using the pressure built up in the pipes. Repressurize, then open another faucet. Repeat until all faucets/valves including the toilet and external shower have been blown out.
If you use a compressor with its own air tank, you can start with a faucet/valve already open, because the compressor's tank allowed the requisite pressure to build first.
Old 11-30-2015, 05:44 PM   #19
2015 30' FB FC Bunk
I'm curious if the pressure loss I was experiencing was not leakage at all, I could have been building pressure against the check valve which was opening as I introduced air, then closing as I shut off the compressor. I kept it down to 20 PSI to be safe, I wonder if I had kept going, build up to 20 PSI, let it bleed out, repeat, perhaps it would have eventually held at 20 PSI.
My Coleman Niagara has a perfect water system and lost pressure almost immediately once I shut the compressor off. It would go down to 0 PSI, but there was some obvious resistance slowing the loss. Then I went inside and opened a faucet and it blew air significantly as if it was charged.
All this indicated to me was that I have no clue as to what I was doing. Hopefully somebody knows for sure. I'd love to be able to pressure test my water system each year.
Old 11-30-2015, 05:52 PM   #20
Images: 59
To think that all the great physics and science quoted in the posts above has fallen to the possibility that it might just be the unloader valve on your air compressor.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Losing air from leveling system gloran General Motorhome Topics 20 08-27-2015 06:33 AM
Losing Fresh Water while driving Shelly M Fresh Water Systems 8 04-29-2014 02:59 PM
Would like the "why" behind one step in blowing out lines in winterization process bonginator Plumbing - Systems & Fixtures 9 10-05-2012 12:12 PM
Losing engine elec. engine dies while driving Clyde Gartma Airstream Motorhome Forums 4 12-10-2011 08:46 AM
