Old 09-09-2015, 05:21 PM   #1
2015 16' Sport
Portland , Oregon
water drainage
Some questions about water drainage. I want to drain my water system and have it be dry for a while for storage. Some things I do not understand..
1. using a blowout plug with compressed air into the city water inlet, will that dry the fresh tank if the petcocks are open, or will the check valve resist the airflow as it would the water? If that won't work, how can I dry the fresh tank? there is water adhering to the top of the tank. Alternatively, what if I blow air through the fresh water tank filler? Is there an adapter for that? The adapter I have is specifically designed to vent air so as to not pressurize the tank.
2. what happens if i blow the air through and do not do anything to the hot water tank such as open the drain valve?
thanks!
leedav is offline   Reply With Quote
Old 09-09-2015, 05:36 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Lee,
I use an adapter I made and blow out the HW tank also..
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-09-2015, 06:10 PM   #3
2015 16' Sport
Portland , Oregon
Originally Posted by ROBERT CROSS View Post
Lee,
thanks. Any thoughts on the first set of questions?
Old 09-09-2015, 08:04 PM   #4
richw46's Avatar
Lexington , Kentucky
It will not blow out the fresh water tank, just open the valve for the fresh water and let it drain, then close the valve. Don't worry about it being dry, you will need to sanitize it when you are ready to use it the next season. If it's empty there isn't much to freeze so no expansion of ice to worry about.
What is the need to have it bone dry?
There is a bypass valve that will shunt water to the heater but you need to close the cold water inlet valve and hot water outlet valve as well as the crossover. Your owner's manual will tell you the location of these valves.
Why do you want to leave water in the hot water heater?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-09-2015, 08:06 PM   #5
2015 16' Sport
Portland , Oregon
water drainage
I figured for a few weeks it would be ok since the hot water would kill any bacteria as long as I waited for it to get to temperature. Bone dry because then I could skip any treatment with bleach or other means.
Old 09-09-2015, 08:09 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't leave your fresh water tank drain valve open... just having a little water in the bottom won't hurt it.. but, do put about 1/4-1/2 ounce of Clorox in it... then run a little water to flush out of the inlet to the tank... shouldn't take more than a cup.
Open the 'low point' valves when you 'blow' the lines.. you will need a compressor which can provide 'volume', not 'pressure'... low pressure works.. under 20PSI I would guess.. but you can follow the numbers in your Owner's manual.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-09-2015, 08:10 PM   #7
2015 16' Sport
Portland , Oregon
The low point valves basically come off the fresh tank. That's why I was wondering. Anyway for sure not to leave them open. Don't want critters
Old 09-09-2015, 11:49 PM   #8
richw46's Avatar
My low point will drain most of the water from the plumbing but not the fresh water tank. It has its own drain valve. It won't hurt to leave water in the hot water heater except in freezing weather. Same for the fresh water tank. Since you're just storing in the summer I wouldn't worry about draining anything. If it's been a few months I just let the water run for about a gallon or two, hot and cold.
The Airstream manual says to sanitize at the start of each season. I normally do that for our first trip after storage when I'm draining the antifreeze from the lines.
-Rich
Rich & Yvonne
2004 4Runner SE
Water tank drainage AIR-Quarius Fresh Water Systems 4 12-15-2009 10:57 AM
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 01:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 04:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
