Old 04-01-2015, 05:48 PM   #1
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Using Ultrasonic Rodent Protection While In Storage
Does anybody with solar have experience with our proposed use case for electronic rodent control while AS is in storage?
As background, we are planning to store our Airstream outdoors for 3 1/2 months and are looking for a rodent repellent solution that would last that long. The non-electronic solutions we've investigated are only good for 30 or 60 days which is shorter than what we need with peppermint drops lasting the longest at 60 days. For that reason, we are looking at a 110V device called 'T3-R Triple High Impact Mice, Rat, Rodent Repeller' that uses ultrasonic sound to repel rodents. It would run continuously while the trailer is in storage without shore power and we are hoping that our solar panels would be enough (with everything else turned off) to keep it powered up while we are away.
Questions:
1) Does anybody have experience with this product ?
2) Has anybody with solar used this device while the trailer was in storage?
demijac is offline   Reply With Quote
Old 04-01-2015, 06:07 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I don't know about the solar aspect of powering them.
I've been using three Victor M753 Mini PestChaser Ultrasonic Rodent Repellent for about 4 years in my Safari at home in NC. It is parked outside right beside a wooded area 100% of the time. No mice in the trailer in four years.
I also have the same in my Excella. It is parked 100% of the time outdoors in Florida, near a creek and woods. No mice in the trailer in two camping seasons, but we do have an occasion gecko.
Alan
A W Warn is online now   Reply With Quote
Old 04-01-2015, 06:38 PM   #3
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
FWIW......I was wondering about these devices myself recently. I did a little searching online and found a few sources that said they didn't work. If I remember correctly the article stated they only effected mice if the mice were in line of sight of the device and mice could get acclimated to the devices.
Landrum is offline   Reply With Quote
Old 04-01-2015, 06:59 PM   #4
Rjpuckett's Avatar
2012 25' Flying Cloud
San Antonio , Texas
Is it April 1st?
Rjpuckett is offline   Reply With Quote
Old 04-01-2015, 07:20 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I always thought they were just another "available only on TV" scam.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 04-01-2015, 08:05 PM   #6
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
Mouse in the House
I tried one of the ultrasonic devices in about 1999. I had a 1996 21' Sovereign and kept having evidence of their presence (they left presents). One day I opened the door to the trailer and there was a mouse sitting right in front of the ultrasonic device. Needless to say I was not impressed with it's effectiveness. I spent a lot of time after that tracking down all the places they could get in and finally stopped the varmints.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 04-01-2015, 11:09 PM   #7
1974 Argosy 20
Kooskia , Idaho
I believe Consumers Reports did a test of them and found them of no value.
Running them from a stock Airstream inverter and solar panels is questionable. Most inverters built into Airstreams take in the range of 1.7 to 1.9 amps just being on, sitting there doing nothing at all. That is about 20 amp hours a day and to reliably have that much power you need a reasonably large solar system (with any reserve for cloudy days). The Airstream supplied one is probably not going to do it. Of course it could be upgraded, but if the mice protection system is not viable, why bother?
Old 04-02-2015, 12:09 AM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I use ultra sonic for insects and dryer sheets, but this is mostly for while we are on the road. I had one mouse one time. Since then, I tried to find and block entrances for the mice.
Seal the front frame rails and remove all food items.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-02-2015, 11:04 AM   #9
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Just picked up my '05 Yukon after it sat in northcentral Florida over the winter...had used two packages of dryer sheets throughout the interior and motor bay to keep out rodents. $550 worth of chewed wire repair and $120 for interior shampooing to get rid of all the poop/pee showed me to not waste money on dryer sheets again. THEY DON"T WORK. jon
B00merang is offline   Reply With Quote
Old 04-02-2015, 12:07 PM   #10
ronpovey's Avatar
Vernon , British Columbia
Never had any success,place mothballs under unit on the ground.
ronpovey is offline   Reply With Quote
Old 04-02-2015, 12:32 PM   #11
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Rubber snakes in selected spots will keep the mice away and every year in the spring, I buy 2-3 large dog flea collars and cut them up into 3-4" pieces and place them in all of the louvered openings; under the bed, fridge, hot water heater, etc., and also in the propane tank. No more wasps, bees, or ants. Haven't seen any spiders either.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-02-2015, 12:44 PM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I have sonic devices in my house and I still keep getting mice in my house. My conclusion, they don't work.
Old 04-02-2015, 12:50 PM   #13
Used in our house....didn't work got 2 cats and haven't had any problems since
jakeandkate is offline   Reply With Quote
Old 04-02-2015, 01:05 PM   #14
1972 23' Safari
Camas , Washington
this may sound odd but a gallon milk jug filled with used vegetable fryer oil works great for catching mice. We found this out by accident. I had a gallon of used fryer oil in the garage waiting to be recycled. For what ever reason there was no lid on the jug. In the spring there was five mice sunk in the bottom of the jug! At first wondered what was in the oil? We emptied the oil into another container and discovered it was mice. So I would think a gallon jug under the trailer with used veggie oil should work.
Pams72 is offline   Reply With Quote
? rodent-damaged wiring mmcpherson General Repair Forum 9 12-26-2009 11:05 AM
Rodent steals the spotlight kevin242 Fun & Games 3 08-15-2009 05:06 PM
Try This For Rodent & Moth Control KANEHILL Winterizing, Storage, Carports & Covers 3 10-22-2007 03:28 PM
Rodent-proofing for storage zimbop Winterizing, Storage, Carports & Covers 10 10-05-2007 07:54 AM
Ultrasonic Pest Control Cracker Our Community 5 04-19-2004 12:50 PM
