Old 10-22-2015, 11:25 AM   #1
2014 23' Flying Cloud
2015 28' Flying Cloud
Kalamazoo , Michigan
URGENT storage question
I will be storing my 2014FC 23D this weekend. I've winterized it and emptied it out. Last year I left the batteries in until I got to the storage facility to power the front jack. Removed the batteries and stored them in my shop with occasional trickle charge. In spring picked up trailer and replaced batteries at storage site for trip home. This year I've removed the batteries and set in storage mode. Any reason I can't just use the hand crank on the power jack to hitch and unhitch??? Please let me know ASAP. THANKS!!
mwilliamsmd is offline   Reply With Quote
Old 10-22-2015, 11:39 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Hand crank works. Reinstall the cover to prevent water from entering.
Old 10-22-2015, 11:53 AM   #3
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I do know that the hand crank does not clear the propane cover. I have a dead spot in the motor and have to use the hand crank on occasion and it is a pain in the butt. You may want to find a tool you can use that is longer. It is a square head you use the hand crank on so a socket may work.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-22-2015, 12:03 PM   #4
1974 Argosy 20
Kooskia , Idaho
There is no reason to remove the batteries at all as long as you charge them properly and totally disconnect them when stored. Save yourself some work and worry.
See my post and tests on the subject and decide for yourself:
http://www.airforums.com/forums/f449...ml#post1602338
Old 10-22-2015, 12:27 PM   #5
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
You can power the jack from your TV's electrical system through the 12 v . connector in the umbilical cord.
Old 10-22-2015, 04:21 PM   #6
WaLee's Avatar
Nevada City , California
To use the hand crank just remove the propane cover.
WaLee is online now   Reply With Quote
Urgent!! Generator Question Kalidas 2011 - 2015 International 52 07-16-2016 05:43 PM
Urgent question about dump hose?!?! Gillpine Airstream Lifestyle 30 10-23-2015 02:36 PM
Urgent Door Question! royalcourt Doors & Locks 6 05-26-2009 02:04 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
Urgent...Jacking trailer hhuber Jacks, Stabilizers, Lifting and Leveling 20 10-06-2003 10:47 PM
