Old 01-02-2014, 07:53 PM   #29
Bbelk's Avatar
2010 27' FB Classic
Just finished and working on landscape. No comercial use, just Airstream storage and our guest house. 36 X 24 with water, electric and sewer.
2010 27FB Classic
1989 190 Class B (Sold)
1977 29 Ambassador Land Yacht (Sold)
Bbelk is offline   Reply With Quote
Old 01-03-2014, 10:59 AM   #30
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Originally Posted by Protagonist View Post
A dump station is generally just a cleanout plug located at ground level; cleanout plugs never have traps on them because they're specifically designed for easy access with a Roto-Rooter or whatever will be used to clear clogs. And remember, your dump station may someday need to serve as a cleanout plug if the plumbing gets stopped up.
If you're concerned about odor, the answer is ventilation. Not venting in the pipe, but rather ventilating the garage. The simplest fix for bad odors is usually "stand upwind." So an exhaust fan (a standard bathroom exhaust fan is fine) loaded right by the dump station would not be amiss.
1+
Having built a house two years ago with 58 foot long heated garage with two 50 amp plugs and one floor "clean out" inside, one outside (for guest campers) and having met all codes, this is precisely what I did. The exhaust fan, if needed will refresh the air in about three minutes.
However, the actual oder from any of this is almost undetectable as I connect my transfer pipe immediately upon opening the dump tube.
It is my understanding all the dump stations I have seen in parks,etc., are without a trap.
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 09-06-2014, 10:59 AM   #31
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Project Update
Well as sometimes happens...best made plans... Here we are almost a year later and no building. The seller informed us prior to closing that he was in the middle of a divorce and at that point we knew there would be problems.
Long story short...no land...no building. We are still looking and have our eye on a 90 x 120 storage building that also has an apartment incorporated into it. Many of the amenities suggested would be possible with this building. Our intention is to lease out space and use part of the building for trailer work. Now it is a matter of working through the process. It sure would be nice to get our trailers inside before the snow flies!
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Old 09-06-2014, 12:13 PM   #32
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
That sounds like a great space! I hope it works out for you.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-06-2014, 12:58 PM   #33
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Thumbs up
14x60 unsure of ceiling height, but it's high. 10 & 30 Amp hookup, no dump or water though.
$250 every two months.
Name:	2014-08-24 19.55.27.jpg
ID:	220991   Click image for larger version
Name:	2014-08-24 19.55.44.jpg
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-06-2014, 01:08 PM   #34
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
cool..hope it works out...cant wait to see the end result.
I have some ideas in my mind about one day way down the road having a little house with a nice storage building on it that I can use for guests (a small loft apartment), the airstream, and a few other assorted toys
PharmGeek is offline   Reply With Quote
Old 09-06-2014, 01:08 PM   #35
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
boldadventure....AWESOME
Old 09-06-2014, 01:19 PM   #36
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
36X60 Pole Barn
Insulated, lots of lights, air compressor, ceiling fans, and my AS has a big bay for itself. Installed outlets in the ceiling to plug the lights into to make replacement easier. Also have reel electrical extension cords hanging from the ceiling. Check out garagejournal.com for lots of ideas for anything having to do with garages. Good luck
tsunami is offline   Reply With Quote
Old 09-06-2014, 01:22 PM   #37
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
^^ salivating
Old 09-06-2014, 01:31 PM   #38
Nomadic , USA
Yeah that is nice indeed.
Old 09-06-2014, 03:12 PM   #39
tsunami's Avatar
Images: 20
Room For Growth
In case I have to get a bigger (longer) Airstream, I've got the room.
Old 09-06-2014, 03:19 PM   #40
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Name:	ImageUploadedByAirstream Forums1410038249.278231.jpg
Having a place to work on a trailer has been wonderful. A friend of mine and I rent a 40 x 65 building for our trailers. No water but we do have all the power we want
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 09-06-2014, 07:13 PM   #41
tsunami's Avatar
Images: 20
Especially in your neck of the wood.
Old 09-06-2014, 07:28 PM   #42
1964 26' Overlander
Milton , ON
That looks like a great space, but you need to get more trailers to fill it up!
What's upstairs?
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
