Originally Posted by Sky
My manual says to blow the lines using 60 PSI...
as i recall the water lines are 'pressure tested' to 90 psi during construction...
so the issue is, how much air pressure is enough to move water, working line by line...
while the manual says "at least 60 psi" i question this and have done fine with much less...
i've also over shot and ruptured the pre pump filter/screen thingie...
the interior volume of the water lines isn't great and doesn't expand much, so a compressor can over shot quickly.
we discussed this issue some in another
toasty's dad thread last spring...
http://www.airforums.com/forums/f458...uck-22185.html
IF using a compressor remember it should be one
without internal oil lubrication...
which is another nasty taste 4 the water lines...
cheers
2air'
