Old 12-05-2017, 07:56 AM   #1
Denton , Texas
Texas winterization needs
Have our 28í International, fully covered, protected from north wind. I know the metal covered storage units warm up quickly on sunny days, am wondering if temps at or barely below freezing, 28-30 degrees, will it be ok without winterizing? Will only be below freezing a short time and it has been in the 80ís here for days.
ElSuenoFarms is offline   Reply With Quote
Old 12-05-2017, 09:10 AM   #2
2001 30' Classic S/O
Marshall Ford , Texas
Well, freezing is freezing. And besides temperature, duration is also important.
The other thing to think about is cause and effect. The effect of freezing with cause you to spend a lot of money.
Just south in Central Texas and needing to drain the water heater,
John
TexAirS is offline   Reply With Quote
Old 12-05-2017, 09:14 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by ElSuenoFarms View Post
Have our 28’ International, fully covered, protected from north wind. I know the metal covered storage units warm up quickly on sunny days, am wondering if temps at or barely below freezing, 28-30 degrees, will it be ok without winterizing? Will only be below freezing a short time and it has been in the 80’s here for days.
For peace of mind, if you wonder if you should winterize, then you SHOULD winterize. It's just like deciding to take in your awning when the wind picks up. The time to do it is when you first think about doing it, instead of running the risk of waiting and then being caught unprepared and having to scramble to get it done.
In the case of winterizing, I routinely check the long-range forecast for my area, and if the overnight low temperature is predicted to fall below freezing before the next time I plan to use my Airstream, I go ahead and winterize. Winterizing is no big deal, and neither is unwinterizing when I use my Airstream again. Some winters I never have to winterize, but one winter I winterized my Airstream FIVE times in between winter camping trips.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-05-2017, 09:18 AM   #4
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I am in Houston, so you are in a little colder area. In 10 plus years of AS ownership I have never winterized. Like you, mine lives in an enclosed metal storage unit. I figure a 10 degree difference between inside and outside temps.
Our dips to below freezing for a few hours overnight, aren't enough cold hours to do anything to the AS, although it can be very effective at killing plants.
If we get one of those rare hard freezes with temps below freezing for a day or two, then I set the furnace to 50 or so degrees and let it run as needed.
Hope this helps.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 12-05-2017, 10:01 AM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I bought my TT in Mineral Wells, TX with a busted tank and plumbing at a greatly reduced price because the PO thought the same about avoiding winterization.
It is mandatory for North Texas. Itís only south of San Antonio towards the Valley one can be casual.
You must not remember December, 1989 here in D/FW. 6 or 7 straight days of temps around 20F. And winds to make it even more uncomfortable. Plenty of houses didnít survive that one. Or New Years 1978 or 1979 ice storms.
Weather is almost always good thru New Years Day. Overnight lows near freezing might not be a problem when temps in the daytime get into the 50s, but thereís no guarantee of it.
Like any other new job it is best with proper tools and supplies. And experience makes it easier.
First freeze is traditionally the week before Thanksgiving. Itís also a great long camping weekend. So consider December 1st the last date.
Mid-March is the other end of things. But because of sustained high winds, cloud cover and overnight lows, itís like an early November blue norther out of Canada. Be prepared to reverse it.
Old 12-05-2017, 02:33 PM   #6
Long Island , New York
Originally Posted by Protagonist View Post
. . . if you wonder if you should winterize, then you SHOULD winterize.
Amen!
Denton is north of DFW, almost in Oklahoma, right? Hands down you should winterize IMO.
Check the line graphs at the bottom of this January chart:
https://www.accuweather.com/en/us/de...monyr=1/1/2018
The overnight lows plus strong winds will probably find the weakest link in your plumbing chain, which could possibly be buried deep inside your floor or a wall.
Why take the risk? Do it once and be done with it . . . Peace of mind all winter . . . ďPricelessĒ as the saying goes!
Good luck,
Peter
Old 12-05-2017, 03:46 PM   #7
2007 22' International CCD
Besides, that far north in Texas, the only thing blocking the wind is the barbed wire fence to your north, and itís down...
Old 01-18-2018, 05:25 AM   #8
Just wondering how you are making out during this cold winter? Did you fully winterize the AS?
The temps in the monthly chart linked in Post #6 seem to indicate a recent low temp just above 0 F.
Peter
Old 01-18-2018, 07:36 AM   #9
2017 27' Flying Cloud
Fort Worth , Texas
Peter
We have been in the teens lately at night here in the Dallas/Fort Worth area. Anyone who did not winterize is probably in for an unpleasant surprise.
billrector is offline   Reply With Quote
Old 01-31-2018, 01:01 PM   #10
Humble , Texas
See you're from Kingwood, so are we. Brand new owner of 2018 International Signature here. We take delivery on Friday, and if all goes well, will be attempting to back it in to it's new fully enclosed storage unit that evening. Would like to chat sometime, compare notes. I'm as green as they come, much to learn. Take care.
James
Selba56 is offline   Reply With Quote
Old 01-31-2018, 01:05 PM   #11
Humble , Texas
Hope this helps.
Think I got a little quick on the trigger, meant to reply with Quotes, please see my reply above.
Space Heater for Winterization jjagnew Winterizing, Storage, Carports & Covers 6 09-18-2010 02:38 PM
Southern Illinois 'One Last Rally Before Winterization' TinLoaf WBCCI Rallies & Events 55 11-10-2009 11:56 AM
Compressors and winterization luckydc Winterizing, Storage, Carports & Covers 7 11-28-2004 11:06 AM
What to do for winterization? FarHarley General Interior Topics 1 11-25-2004 06:25 AM
Winterization Blues - Water Heater Question BrianRegan Water Heaters, Filters & Pumps 0 06-13-2004 12:36 PM
