05-22-2010, 10:10 AM
2004 25' Classic
Prescott
Summer Time Storage Temp?
We are in Florida and would like to get some opinions on what is a good temp. setting for the air conditioner during the summer time while not in use. We won't be using it for about 3 - 4 months. I do have a 30 amp. hook up but would like to conserve electricity without doing any harm to the inside of trailer, so, what are your thoughts ???
Julia & Bob
W/ Deedee & Boo
AIR #30685
05-22-2010, 10:32 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We Lucy is stored at our house or at SuEllyn's Dad's house in Jacksonville in the summer, we leave the air conditioner on and set the temperature at 82 degrees. Both of these locations have 30 amp RV outlets. This had worked well for us over the past 4 years.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
05-22-2010, 10:40 AM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
RLS, I don't know what kind of ceiling treatment you have in your trailer. Our '97 has the white vinyl fabric, and we found out that Airstream wont' cover it's detaching from the ceiling if the interior temp exceeds 90f. We now have several places where the ceiling is drooping. With that said, I would suggest a thermostat setting of less than 90f.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
05-22-2010, 11:22 AM
Santa Rosa Beach
I forgot to add that we also store Lucy with silver reflective insulation in her windows and skylight when she is stored. I think that this helps tremendously in protecting her interior.
Brian
05-22-2010, 03:03 PM
Cyclist
2007 28' International CCD
Windermere
I keep mine under a canopy. Inside AS temp hits very high 90's most days.
I do have a portable dehumidifier standing in the shower that I run. Pulls a couple of gallons/week out of the air.
No heat related issues after 3 summers.
Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
05-22-2010, 03:07 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
I left mine in a rental storage shed/garage for two months during hurricane season (Aug/Sep) in Fort Lauderdale with no ill effects. No AC, just left the roof vents open and closed the garage door.
05-22-2010, 07:15 PM
2004 25' Classic
Prescott
Thanks for the input I have it set at 92 degrees right now. I have noticed that the ceiling vinyl up in the curve area towards the side has pulled away some. I can push it back up and it wants to hold but not for long. You would not notice it if not shown where it is. Is this from the heat? I think this has set out in the sun for some time from the PO. Where I have it is under the oak trees ( not the best but has to be till I get the pole barn built around it ) so it does have shade.
Julia & Bob
W/ Deedee & Boo
AIR #30685
05-22-2010, 07:55 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
RLS, I think it is. That is what mine looks like in several places, the big section from near the door to the A/C unit has actually separated from the ceiling. From what I understand this has happened to quite a few trailers. The heat makes the glue lose adhesion. (Which makes sense)
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
05-24-2010, 03:57 PM
Maniacal Engineer
Lopez Island
This seems absurd..... how does one travel on a sunny day?
Perhaps Airstream should use heat-resistant adhesives...
- Bart
05-27-2010, 11:50 AM
Sierra Papa
2007 25' International CCD
Preston
, Idaho
Along this same line of thought, has anyone had troubles leaving a trailer in storage plugged in full time? Is this the most effecient way to keep the batteries charged up? Does it cause pre-mature wear on the inverter system? I have the luxury of storing inside an insulated building with power and really do not need to leave anything of consequence turned on in the trailer.
05-27-2010, 03:44 PM
2010 27' FB Classic
N/A
Originally Posted by barts
this seems absurd..... How does one travel on a sunny day?
Perhaps airstream should use heat-resistant adhesives...
- bart
x2, I thought the same thing. I hope it's not so. It's 95 here today in the shade and it will only get hotter as the summer begins.
05-27-2010, 04:07 PM
2005 25' Classic
Austin
I store my AS in our insulated garage where the temperature usually does not exceed 82 degrees. I sure hope the ceiling vinyl does not come loose when we are out on the road when it is 100+ out.
Dennis
05-27-2010, 04:39 PM
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I got my information from the gentleman who is going to fix my ceiling. Obviously our '97 is well outside of its warranty. However, I have no reason to doubt his information. Many adhesives are not particularly heat resistant. I am surprised that Airstream doesn't use one which is more heat tolerant.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
05-27-2010, 05:39 PM
2004 25' Classic
Prescott
I think what Aviator means, is high temp. plus time equals trouble. I'm sure the trailer has no problem with 100 + degrees for a short time. It's the Loooong sitting time baking out in the sun for Months that will take a toll on the interior. JMHO
Julia & Bob
W/ Deedee & Boo
AIR #30685
05-27-2010, 06:32 PM
Lost in America
Santa Fe
, New Mexico
Sierrapapa, I would not leave your unit plugged into shore power for a month or more while in storage as you could cook the water out of the batteries. Be sure it is fully charged when you put it in storage and then hook up a Battery Minder to the batteries and turn off the battery disconnect. It will be ready to go when you are...
05-27-2010, 07:19 PM
2000 31' Land Yacht
Central
My guess would be time and temp work to remove plasticizer in the vinyl, making it shrink causing more stress in the ceiling curve as it is trying to make a straight line.
When I checked my ceiling vinyl AS either cut it too short or shrinkage is pulling it away from edge. It's not dropping so the glue is still working.
05-27-2010, 07:31 PM
Central
, Mississippi
My understanding is Airstreams first shot at the soft headliners was not very good, the adhesive didn't work properly and let go in most units. As far as storage while plugged in, make sure and get a multi stage charger to keep from boiling the batteries dry.
Mine stays plugged in 24/7 with a multistage charger and I've had no issues.
A rain sensing Fantastic fan will automatically open and discharge the hot air while keeping the insides dry...
05-28-2010, 01:49 PM
2005 19' Safari
GLENDALE
, AZ
Being in Phoenix, our 19-foot Bambi sits outside in 110+ degree weather every summer; and we don't use the air conditioner or open the ceiling vents. We bought it new in 1995 and the inside seems to have survived the heat just fine, sort of like what you'd expect with your car or tow vehicle. We put sun shades in the windows, but I'm unsure whether that really helps much. It mainly keeps people from snooping inside, which is pretty difficult anyway due to the heavily smoked glass.
In the past couple of years, we have had a couple of weeks each year when it is 115-118 degrees, so we are not particularly concerned about it sitting in the heat. I would worry more about the severe cold and snow in the northern states. We don't worry about pipes freezing or water damage. Also, hail is extremely rare in Phoenix; and if we ever see any, pea or marble size is about as big as it gets.
06-22-2010, 07:48 AM
2010 27' FB Classic
N/A
I wonder if a product like 303 would prevent that from happening, or would it turn the liner yellow in a few years and not be worth doing?
Anybody use anything other than water and some soap to keep it nice?
07-06-2016, 07:36 PM
2016 30' Flying Cloud
New Caney
Storing 2016 AS Flying Cloud 30FB Bunk in Texas Heat
We keep our 2016 AS Flying Cloud 30FB Bunk stored in our shop. It is a large metal building with some insulation. It does get hot inside the shop. We have a dedicated 50amp circuit for the trailer to run the A/C as needed. Since we are new AS owners, I am trying to determine the best way to store the AS when we are not using during the summer heat. We live about 35 miles north of Houston so the heat and humidity are pretty high. I have a thermometer inside the AS that measures temp and humidity. I also have a small dehumidifier running inside the trailer. Without A/C running the range of temp is 72 deg to 97 deg. Humidity ranges from 30% to 43%.
What are the recommended practices for storing AS trailers in the summer? A/C on or off? Vents open or closed? etc... I am looking for advice as to the best way to store my trailer during the heat of the summer inside a metal building.
Mike & Mary Allison
New Caney, Tx
832-242-4406
