Old 07-11-2014, 11:57 AM   #1
DTR
Adventures with GypsyRose
DTR's Avatar
1988 32' Excella
Plano , Texas
summer-do I need to drain antifreeze
Do I need to drain the antifreeze if I am not using the trailer?
DTR is offline   Reply With Quote
Old 07-11-2014, 12:02 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I would say no if you are not using the trailer.
When you use the trailer and hook to city water it will be pushed on through by the water.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-11-2014, 12:34 PM   #3
DTR
DTR's Avatar
1988 32' Excella
Plano , Texas
Thank you. I was concerned about staining or odor if left in the lines. This was the first winter I put anti freeze in it. When I was living in it full time it wasn't necessary.
Old 07-11-2014, 01:18 PM   #4
m.hony's Avatar
2013 30' Classic
It has no odor that I can detect- or it is not an offensive odor-
If it stained anything it should be the inside of a pipe or holding tank that you would never see so if it turned pink it wouldn't matter.
I can't imagine not using my trailer...
I end up winterizing twice because we go campin' again after I winterize...
TAC #MS-10
Airforums #70955
Old 07-11-2014, 01:26 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We've never had RV antifreeze stain anything in the trailer. Not sinks, toilet, tub, or the occasional drips that get on the floor or counter tops. Trailers come from the factory with RV antifreeze n them, and that is not flushed out until the dealer preps the trailer for use. That may be a couple of years. It's very ok to leave in. In fact, you may want to add more to the traps in the sinks and tub, and fill up the toilet bowl to keep the seal wet.
Chris
Old 07-14-2014, 10:30 AM   #6
DTR
DTR's Avatar
1988 32' Excella
Plano , Texas
Thank ya'll so much for the info. There are times I miss not living in her. Although it is nice not to have to modify yoga poses so I don't touch the ceiling.
Old 07-14-2014, 12:14 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
There is no real reason to leave the antifreeze in the water lines. It's only use is to push the water out of the lines. I always blow the antifreeze out right away and the trailer is then ready for use. Put a small dish of antifreeze in your house freezer and see what happens to it.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Winterize, Pink Stuff, RV Antifreeze, Drain and Flush masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 11-19-2013 07:40 PM
Need Antifreeze resevoir. nemo834 Classic Motorhomes 2 08-05-2010 10:31 AM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 02:33 PM
RV Antifreeze Quality jcanavera Winterizing, Storage, Carports & Covers 8 11-27-2002 04:32 PM
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 08:01 AM
