Old 08-29-2013, 08:09 PM   #211
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Originally Posted by tkowalyk View Post
My new home for my Airstream
Freakin sweet!!!
I'm workin up to something in that realm - my patio is close by and so it will tie in eventually
PharmGeek is offline   Reply With Quote
Old 08-30-2013, 04:47 AM   #212
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Perfect.....
Attachment 194503
How much to Camp there?
Do we need reservations?
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-30-2013, 05:22 AM   #213
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
Bob,
It is pretty sweet. The rates are low!
We have wired rock speakers - we can control satellite radio, Pandora etc through my iPhone.
We also have lighting around the patio and to the rear door so we can load / unload in the dark.
We're lucky to be able store the Airstream at our house. We designed and built the EP Henry patio to complement the Airstream. So on the weekends we can't get away - we can just walk out the back door and light a fire!
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 08-30-2013, 06:53 AM   #214
1981 31' Excella II
New Market , Alabama
I am planning a new shed project. I plan on using the fiberglass reinforced stuff and also plan on putting dog fence material in there which I have used before. The dog fence is not as thick as the rebar mesh but there are more wires per foot. If you don't want cracks, do it in sections. The fiber reinforced stuff is like $80 a yard and the cheap stuff is $70 a yard so that is a no brainer. The dog fence is cheap enough that even if is does not help, the cost it not that much and it does help because I have busted up slabs with it in there. Eventually, I will also make an Airstream shed. Unless you are building a runway, concrete costs should not be more than a few hundred dollars if you pour it yourself. Of course, the smoothness and surface finish take some experience to get right. You don't want to go any thinner than 4 inches and probabably don't need over 6 inches unless you are going to have full dump trucks driving over it. Figure your yards needed and do a cost estimate. If you have a really big driveway then 4 inch thick looks better. The labor for 6" versus 4" is about the same and don't let them tell you different.
Perry
Need to get our driveway done.
Thickness of slab, fiber reinforced or rebar?. Which did your contractor recommend?
Old 08-30-2013, 07:56 AM   #215
We have a very short 26' X 18' driveway. I'm thinking 4" thick as there's no real load on it, with a 6"X6" wire mesh rebar. If it's that close between the two on material cost I will probably do both also.
The Winters can be brutal here.
PFC
"Tahawus"
RLC
Old 08-30-2013, 09:22 AM   #216
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We poured a new apron for the garage and they mixed the color into the truck mixer bowl to match the cobble stone drive.
Old 08-30-2013, 11:49 AM   #217
1981 31' Excella II
Here is a yardage calculator for those who want to get some idea how much concrete is required and you can check to make sure that your contractor is not ripping you off.
Concrete Calculator - The Concrete Network
Perry
Old 08-30-2013, 02:08 PM   #218
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
good info...my brother's original calculations came up about 1 yard short - 200 dollar mistake...better to pay for a bit extra than have to pay for them to go get more!!
Old 08-30-2013, 02:30 PM   #219
1981 31' Excella II
You always get extra. The only problem with that is that they will usually want to clean out their truck and dump the excess on your property or at least they do that out here in the country. What I do is make a form for a ramp and put excess there and make up the rest with bags and my Harbor Freight cement mixer.
Perry
Old 09-03-2013, 01:44 PM   #220
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
@Perry - my brother I think was trying to cut it too close, but largely it was just a matter likely of a bit of innexperience...which is fine cause I am getting this all at cost of materials and for manual labor so its a real deal I think. As it relates, the extra he ordered post hoc was actually barely enough...he had about a wheel barrel full left after completion....whew....
Today I just payed for materials delivery for block, sand, mortar, gravel....digging the footer soon around the perimeter of the pad and laying the retaining wall...
Last detail will be moving the darn dirt pile - you may ask why we are moving it twice...a good question....dont ask me...argh
I then need to put in a fence back for that section and have some sort of gate...I am think 10 foot wood planks of some sort and a couple 6x6's to have it be able to have some hardwar and such to allow "doors" or "gates" to open and close....my brother will not be doing this...rather my carpenter I think...need to get a quote from him... should not be too difficult of a job I would think....it needs to be functional, nothing too special...
Ive thought about sticking with the chain link smaller type fence and make a gate with something like that...but I kinda like shielding from view my AS...even though I live in a culdesac still will be nice to keep it out of view...I guess...
I want to go ahead and get the quote from my carpenter about a wood structure/roof for the AS as well...I may just go ahead and have it built and avoid the frustration of debris, bird poo, etc...I was going to wait till march/april to do this, but perhaps may just go ahead and "get-r-done" in the next couple months.
Old 09-03-2013, 02:14 PM   #221
richinny's Avatar
2011 34' Classic
i always liked the gate Batman had at the Bat Cave!
Ricky
Old 09-03-2013, 02:19 PM   #222
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
the one I recall was driving through a waterfall? that would be sweet! unfortunately this may present a cost issue for me
I am actually thinking that perhaps I will just try for a gate for a while that is on the cheap...for now...just adapt something with the chain link fence already there to allow relatively easy opening and closing. I checked home deopot for something like this...they had only small gates...ideas?
Old 09-03-2013, 09:29 PM   #223
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Tom K has raised the art of "Driveway Camping" to a new and lofty level.. Having magic rock speakers, firepits and lighting for night loading and unloading may eliminate the need to drive off to an RV Park.. I'm with Robert.. We're hoping to stay there when we next get back to Pennsylvania...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-04-2013, 01:38 AM   #224
switz's Avatar
2014 31' Classic
Images: 8
Since fall is rapidly approaching, I would think a roof over the trailer for the winter to keep the snow and leaves off would be a great idea and you still have time to build it before the trailer arrives.
At least think about putting the necessary footings in place for the roof structure while everything is torn up so you do not have to replant a second time and practice moving dirt piles again....
