I thought I had read somewhere on the website that storage on a concrete pad can cause corrosion problems. I did a search but couldn't find anything. Can someone give me some information about whether storage on concrete can cause corrosion?
I only remember that concrete leaches chemicals from or to the tires therefore you should put down a protective sheet or mat under each tire.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
I block my Sovereign 31' tires on wood each year. I don't like the varmit or the dirt that builds up under the trailer when a cover is on it. I think a cover that drapes the trailer to the ground keeps moisture in and contibutes to corrosion conditions more than anything.
Water + Lime + Aluminum = battery which will etch the aluminum. That being said as long as you don't grind up the concrete and through it on the trailer you should be ok. I assume that the concrete was sealed after it was poured.
Dave TAC# MI-1 Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
I have mine indoors for storage and I place an outdoor type sun room rug on the concrete and pull the Safari onto that so that it does not get parked/stored while on the concrete directly.
This spring will place 4 seasons (roughly 4.5 years) on my current tires, so tires are on my list of things to replace, batteries too, after I install a 3 way converter from best converter.
My father in law, some of you met him at the Beverly Beach Bash is one of those Super Smart Engineer types. He made a living with concrete. He built Nuclear Reactors for the Navy. Anyway, he was telling me this interesting Tidbit about the Hoover Dam. The thing was built in 1937 and the concrete is still curing.
One more Concrete story, we had an oil tank removed from our yard because we switched to gas heat. They guy came with a small backhoe that had a giant scorch mark on the side of it. He told me it happened when a bag of concrete caught on fire, the paper in the bag lit up some rags and they had a fire. And it all started with a rain leak. So let me get this straight, it started raining on the concrete and it caught on fire? Well yea, of course... They looked at me like it was a stupid question. WHo knew that a bag of concrete could catch on fire.
Oh yea, i have no idea whether you can park and AS on concrete, I digress.
Aunt Gladys, 28FT, Intl' "Man, it's hot here, is the heat on?"
Did you know that some brands of powdered coffee creamer ignite when placed over a flame? We quit making it available to our inmate population just for that reason. Nothing is safe anymore.
AIR #0078
3.73 rear end
I don’t believe parking a rig on a concrete surface will harm it. After all, if one has a garage, it more than likely has a concrete floor, and we park our cars on them for years, with no problems.
Yes, raw concrete is a caustic, but solidified and cured concrete is not.
A nice flat slab and a carport to park under would be the best solution for me, after indoor storage, of course.
__________________ Jeff & Cindy Remi & Hunter '81 International 31'CB WBCCI #7026 Air #17054 "Fus-A-Lodge"
What about prolonged storage? Like parking it at a lake on a concrete pad? Would you recommend jacking up the tires and "putting on blocks" and then mounting the tires when it is time to go? I know the tires will rot over time and wouldn't want to use it with a flat.
Any ideas? I know its not popular but sometimes necessary.
Cold setting cemment has Calcium Chloride in it which can generate heat, but the rest of the mix is dominated by Calcium Carbonate which will not burn. I suppose it is possible for the CCl to generate enough heat to light up the rags if the mix was not even enough and there was some concentration that got wet. It is a bit surpising but I certainly would not say impossible.
Your Father in Law is right about the curing process. It will continue to cure for may years. Look how long the Colisium has lasted.
Thanks!
_________________________________
Roadsub
2005 25' Safari SS SE LS
Storage on Concrete is better than in the grass. Lees direct mositure exposre from underneath.
