Old 08-23-2015, 06:28 AM   #1
golfarch's Avatar
2007 27' Classic FB
Myrtle Beach , South Carolina
Storage - Fresh Water Tank
I live in Myrtle Beach, SC and was wondering...after the fresh water tank has been sanitized, should it be stored empty with the peacock drain open?
Would it be better to fill it with fresh water before storing?
Or, leave it empty with valves closed.
"The Percolator"
golfarch is offline   Reply With Quote
Old 08-23-2015, 07:38 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Leave it empty especially if you store it where it may freeze.
Old 08-23-2015, 08:51 AM   #3
richw46's Avatar
Lexington , Kentucky
Store with the valve closed to prevent bacteria and bugs from entering. For any freshwater system you want to keep outside air from getting into the "clean" area.
In winter, store without water to prevent freezing. (Once it's drained there won't be enough water to freeze that will cause any problems. When water freezes it expands, causing things to break, but with just a small amount in the bottom of the tank there's room for it to expand.) During the season it's up to you. Some store water in case of emergency, I prefer to keep mine empty so I can put some fresh water in before leaving so we can flush the toilet, then fill it up just before we arrive at the boon docking location. If we'll have fresh water then I rarely keep more than about 5 gallons in it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 08-24-2015, 04:34 AM   #4
golfarch's Avatar
2007 27' Classic FB
Thank you. Will Do.
"The Percolator"
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Healthy/Green Fresh water storage tank SteelyDan Classic Motorhomes 23 03-27-2012 08:55 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
Locked Out of Fresh Water Storage Tank pronghorn1 Exterior Storage Compartments & Access Doors 11 07-06-2010 02:39 PM
