Old 11-30-2014, 09:55 AM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
Steep driveway dilemma
hello fellow air-streamers ... these pictures might help those considering parking their AS at home but have a steep driveway. It is possible!
i don't have a tow vehicle yet so decided to try my local towing company. The guy was such a pro, took one shot at it .. the trick is the hydraulic hitch that can be lowered and raised very easily.
the other trick is to have some wood planks on hand, 2x4's should do it, have enough pieces to stack up to make a "ramp" , i was amazed at how simple a solution this was.. as soon as the the rear of the trailer touched the driveway we laid down the planks and raised the trailer up a few inches. This worked like a charm.
this might a little more tricky without an hydraulic hitch but with enough wood I'm sure possible with a regular pickup trick tow hitch. I spaced on taking pictures when using the wood ... will update next time.
nickclifford is offline   Reply With Quote
Old 11-30-2014, 10:12 AM   #2
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
I used 2x10 s getting in and out of our steep driveway. I placed them where the rear would get a lift just before the rear would scrape.
I keep an inventory of some 2x12s too but the 10s are lighter to handle and work fine.
I now keep it in a storage garage so problem solved but if I need to get it to my shop, the steep driveway is always an impediment. By the way the WD distributing hitch bars get a real workout if not careful.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 11-30-2014, 09:52 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Steep driveway... not too bad.. but a crowned road and curb drainage.. and steep drive incline... (thank you 'civil engineering' .. not very Civil in our case)....
Solution? Partial... ramps made of 2x4's.. laminated together...
Let's see if I can nail a pic up here...
I also have several other boards 2x10 mostly for 'shimming' as necessary.
Peace and Blessings..
Channing
WBCCI# 30676
Parking on steep driveway KarensHere Solo Streamers 23 01-05-2013 02:49 PM
HELP getting 19' Bambi into steep driveway kimd8888 Towing, Tow Vehicles & Hitches 36 09-05-2012 08:01 PM
I have a steep driveway.. Help! Airslide Tow Vehicles 46 06-05-2009 10:03 PM
How steep is too steep? Tin Diesel Towing, Tow Vehicles & Hitches 14 02-12-2007 01:03 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
