Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 01-26-2004, 02:10 PM   #1
Navigator
Profile:
Snow Load
Sitting here in a nice warm comfortable house, I see the snow piling up on my coach outside. Am starting to get worried.
Has anyone done any calculations on how much snow a dual axle 31 ft. A/S can take, or more precisely weight of powdery snow per inch of snow. Man I dont want to go out on a ladder in that stuff.
Dick
Navigator is offline   Reply With Quote
Old 01-26-2004, 02:39 PM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
This isn't exact but is from Ask Jeeves: Heavy snow occurring in 25-35 degree weather can contain 3" or a bit more water per foot. Colder, fluffy snow can be 2" and up per foot. The overall weight on top of a trailer shouldn't be excessive. You aren't bouncing your trailer down the road and a lot of the snow will slide off the rounded sides of the roof.
I would worry more in constant cold conditions where snow can slump and turn icy, then collect more snow on top of the first. You shouldn't have to worry about multiple freeze/thaw cycles.
Good question -- other North-Central members please pipe in:
Old 01-26-2004, 02:51 PM   #3
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Turn the furnace on about 60 and the snow will melt right off I found out just how thermally efficient Airstreams ain't I have left the heat running on mine because I am working in it over the winter. We picked up 3" of snow a couple of weeks ago, by late after noon you could see where the ribs were. Yesterday we picked up 1" snow with 1/4" of ice with more on the way, but it just kind of melts and runs down. BTW the power was out for a couple of hours around lunch time, just went to the AS and fired up the stove and cooked a big pot of stew and grilled cheese for lunch for everybody...who says an AS doesn't come in handy
Aaron
Name:	ice dreams2.jpg
Old 01-26-2004, 03:05 PM   #4
CanoeStream
Images: 13
Good observation Aaron -- but what hitch height do you use to keep your tanks from hitting bumps in the road...?
Are your tanks well secured at the top to keep them from tipping over? This is always the first lesson in dealing with SCUBA and tanks for medical gasses -- and they aren't even flammable.
Old 01-26-2004, 03:35 PM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Canoe stream,
You mean the hoses won't keep the tanks from turning over There is a piece of aircraft cable running thru the collars and fastened to the LP rack on the AS. The hitch height still remains to be seen. Actually just got my 30# worthington's back. But given the cold weather and the amount of LP I have been going thru I might just stick with the 100#'ers for a little longer.
Aaron
Old 01-26-2004, 03:35 PM   #6
Navigator
Profile:
Canoe,
Thanks for the input. I used your #'s and made the following assumptions:
8ft. wide trailer has 7ft. width of snow (6" ea. side flows off)
1 foot of snow has 2" of water
1 cubic foot of water weighs 62.32 lbs.
......than 1" of snow weighs approx. 6#/linear foot of trailer
if you use 3#/ft. than its 9#/linear foot of trailer, or
in my case with 4" of snow and an effective length of 29 feet of trailer, the snow load is 1054#.
I'm going out with the broom.
Dick
Old 01-26-2004, 03:45 PM   #7
CanoeStream
Images: 13
I had trouble when I divided acre-feet by furlongs-per-fortnight. Still I came up with a top end of 1000# total load. I don't think that's a big problem and it won't be up there long for you in Delaware -- even with the colder temp high pressure (blue sky) following a snowstorm. If 100 of us get up on ladders somebody is going to get hurt. I suspect we'll get more northerners providing their feedback this evening...
Old 01-26-2004, 03:50 PM   #8
hohne
hohne's Avatar
Profile:
...You might be able to blow it off with your 200 MPH leaf blower...
hohne is offline   Reply With Quote
Old 01-26-2004, 04:00 PM   #9
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
You know, I had my furnace on upwards of 72 degrees and the I found that on the Safari, it barely melted anything on the roof.....seriously!
Old 01-26-2004, 04:17 PM   #10
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Eric,
That is because you have one of the fancy new thermally efficient Airstreams Besides I can buy a lot of LP for the price diffence between a new and a vintage unit. I am willing to bet too that a lot of the fiberglass insulation in mine is matted, and the new stuff has more R per inch than the old stuff. BTW I haven't noticed in everybody's factory tour pics, but are they using any type of thermal break between the ribs and the interior panels? And are the interior panels still aluminum?
Aaron
Old 01-26-2004, 05:04 PM   #11
Silvertwinkie
Aluminut
You know, I thought that they used the same R value since the fiberglass is fiberglass and isn't very high tech, but I suppose that there is a difference if it melts the snow off you unit and you could be right, if matted it would loose a bunch of R value.
When I was at the factory, I saw the shell be built, shell joints inside sealed with some sort of grey looking caulk, the shell mated to the chassis, and then fiberglass followed by alum skin on the inside wall, followed by either that carpeted suff and/or that sponge like plastic stuff (real tech term I know).
Also, if it makes a difference the newer ones (at least the Safari line) seem like the windows have a cold chill or slight breeze that passes through them when cold out and the windows closed....not sure if the Classics are the same.
Old 01-26-2004, 05:13 PM   #12
Navigator
Profile:
Canoe,
Interesting that you mentioned that! A long, long time ago we calculated furlongs-per-fortnight, and it comes suprisingly close to: get this! light-years-per-eon!! Dont take my word for it, check it out. BTW how cold does it get in central MN? I was up there in Oct. to pick up my A/S and the thermostat fritzed on my tow vehicle. Guy in Brooklyn Park charged me $130.- to put in a new thermo. Brr.
Dick
Old 01-26-2004, 05:50 PM   #13
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Eric,
They have actually come up with a fiberglass insulation that has better R value than the stuff of 20+ years ago. Just don't recall what the difference is. I just know that the new stuff has a better R per inch value. I would think that any single pane window would give you a chill, you might try putting a thermal tint on it? Some of mine have a mirror tint on it that is great for bouncing the sun, but make it kind of dark on the inside. We use it on a couple of the windows at our house too, it helps keep the heat down on the inside in the summer but I don't think it does too much in the winter going the other way. LOL
Aaron
Old 01-26-2004, 06:04 PM   #14
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
There have never been any reports of any "snow pile up" damage to any Airstream trailer.
Keep in mind the the trailer is semi-monocouqe construction.
It by leaps and bounds will take more snow weight than any SOB.
With that thought in mind, has anyone ever heard of a brand X having a roof cave in or become damaged by snow?
I never have.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
