Old 12-09-2013, 07:29 PM   #1
Bend , Oregon
Single Axle Trailer Storage
I have a 2012 22' Sport with a single axle. It's spending it's first winter in garage storage. After reading the various posts here on airforums it seems like I should take some of the weight off the axle by getting it up on jack stands. Seems like there is some debate on whether to put the jack stands on the "official" Airstream designated jack pads or the axle mounting plate. Can anyone comment? Also can someone tell me where the axle mounting plate is? I've attached a picture of one side of trailer looking from back to front. I've attached a piece of red electrical tape where I think the axle mounting plate is. Is the red tape in the correct spot? Thanks!
chaeha is offline   Reply With Quote
Old 12-09-2013, 07:38 PM   #2
The Airstream "jack pad" designation, is for stabilizing only, not lifting.
Install the jack stands on the axle mounting plate, just rearward of the axle tube.
Old 12-09-2013, 10:18 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Well this is new to me, but then what do I know? So Should you store a single axle up on jacks? What's the logic - to eliminate a "set" in the rubber of the axle?
DryFly is offline   Reply With Quote
Old 12-10-2013, 04:59 AM   #4
2013 20' Flying Cloud
Cream Ridge , New Jersey
I used the axle mounting plate to lift the trailer with my floor jack. Then I placed the stands under the axle tube just inboard and right next to where the tube goes through the axle mounting plate
Joe Palmieri is offline   Reply With Quote
Old 12-10-2013, 05:14 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not a bad idea to attach reflective tape permanently at the correct spot. Being that it's a single-axle trailer, whenever you have to change a tire, you'll need to use a jack. Reflective tape allows you to find the correct spot easily by flashlight if necessary.
And if you need to call roadside assistance, you can tell the service tech, "Put the jack where the tape is."
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-10-2013, 07:01 AM   #6
A single torsion axle has nothing to do with how you treat the axle.
Long term storage method of any trailer that uses torsion axles, is the same.
Removing all the weight from the axles, is the best.
But still keep in mind that the rubber rods must be exercised every once in a while, in order to stay alive and well.
Old 12-10-2013, 09:09 AM   #7
Bend , Oregon
Thanks everyone for your replies. Still want to be sure of the exact location of the 'axle mounting plate' before I put a bottle jack or floor jack on it. Can anyone comment on the photo I attached at the beginning of the post. Is where I stuck the red tape the axle mounting plate?
Old 12-10-2013, 09:12 AM   #8
DFlores's Avatar
1968 22' Safari
"axle mounting plate" is the vertical plate with no horizontal element to it
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 12-10-2013, 09:59 AM   #9
Bend , Oregon
DFlores thanks! Looks like I can see the "vertical" axle mounting plate in the photo just behind what my red tape marks.
Old 12-10-2013, 10:05 AM   #10
Four bolts hold each axle in place, 2 on each side.
The "axle mounting plate" is a vertical plate that is welded to the side of the steel frame, and that the 2 5/8 inch bolts go through to hold the axle in place.
Old 12-10-2013, 10:16 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I've been told you're not supposed to support any weight on the axle tube. I lift the axle plate with a jack, and place the jackstand along the axle plate adjacent to the jack.
David
Old 12-10-2013, 11:06 AM   #12
1972 Travelux Princess 25
Cobourg , Ontario
Jacking up a car or trailer for the winter takes the load off the tires and prevents flat spotting and fatigue. If you can let the pressure down to 10 - 20 pounds and pump them up again in the spring, so much the better.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 12-10-2013, 11:38 AM   #13
NEVER, EVER, place ANY jack of any kind or description, under the axle tube.
To do so, can and will cause the axle to get out of alignment.
