Old 01-07-2016, 08:34 AM   #1
1993 25' Excella
CLeveland , Ohio
Shut Off Positions and Winterizing
Hi,
All water has been removed and I want to add antifreeze.
Two Questions:
1) Should all of the pictured valve shut offs be placed in the opposite position of the picture?
2) If I attach a short hose on the outside faucet and put it in a gallon of antifreeze AND then turn on the water pump, will it flow through the entire system? The kitchen and bath faucets would be open.
This is on a 93 Excella.
Akronguy is offline   Reply With Quote
Old 01-07-2016, 08:55 AM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
You need to isolate the water heater so as not to waste gallons of antifreeze. Turn off the input and output. Leave the middle on.
The method I use to winterize is to disconnect the input side of the water pump, add a short piece of hose and pump in a antifreeze until it comes out of each water source. Don't forget the handheld shower and toilet.
This is done after blowing out the lines with compressed air thru the city inlet. Open up you low points of your water lines. These are probably in between your axles on the curb side.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 01-07-2016, 09:02 AM   #3
1993 25' Excella
CLeveland , Ohio
Thanks again! I see you answered my question on Facebook too.
Old 01-07-2016, 09:04 AM   #4
1993 25' Excella
CLeveland , Ohio
By you saying "the middle", do you mean the short pipe? That remains in the same pictured position and shut off the other two......correct?
Old 01-07-2016, 10:34 AM   #5
2014 25' FB International
2005 22' International CCD
Red Deer , Alberta
Correct. Open short pipe(bypass valve) and close the other two valves to the top and bottom of the water heater. In normal non winterizing use, the short pipe valve (bypass valve) should be closed(not open as in your picture) and the other two valves open.
Mangin is offline   Reply With Quote
Old 01-07-2016, 10:43 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The 3 valves should never be all opened at the same time.
Top and bottom valves open, middle valve closed for normal operation-
top and bottom valves closed, middle valve open for winterizing with water heater having been drained-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-07-2016, 11:45 AM   #7
1993 25' Excella
CLeveland , Ohio
Thanks everyone. I have corrected it!
Old 01-07-2016, 05:41 PM   #8
1996 25' Excella
Tillsonburg , Ontario
That's how every one I know does it!
JCW
JCWDCW is offline   Reply With Quote
Valve positions for winterizing Tahoe John Winterizing, Storage, Carports & Covers 8 03-23-2013 07:52 PM
How to Weigh Individual Wheel Positions Ridgerunner3 Tires 9 03-11-2013 04:01 PM
Differences in weights among wheel positions Jammer Tires 1 02-27-2012 08:20 PM
Furnace blows cold and won't shut off svander Furnaces, Heaters, Fireplaces & Air Conditioning 13 01-08-2012 10:45 AM
Water Valve On/Off Positions spat61 General Motorhome Topics 17 12-18-2010 08:57 AM
