08-20-2017, 07:58 PM
Wentzville
, Missouri
Short term storage procedure
Just got home with my new 2018 classic and cant find good info on short term storage procedure. Should i turn battery off? I emptied all tanks. Not sure what else needs to be done
08-20-2017, 08:02 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Define short term. I think you would be fine to plug it up and forget it. If no shore power then turn batts to store and you should be good.
08-20-2017, 08:28 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Solar? Solar with sun? That pretty well takes care of the batteries.
08-20-2017, 08:48 PM
2019 27' Flying Cloud
Kansas City
, Missouri
Put it away clean and dry.
We like to empty all tanks and open and drain low point drains.
Keep refrigerator doors ajar.
Double check that the tv antenna is powered off, the pump and water heater are off, propane off.
Set battery to store unless you have solar.
Check that stove vent, bathroom vents, fantastic fans all closed.
Check that all awning hooks are secured.
We also use a few buckets of damp rid to help with humidity
Close the blinds to keep out the sun and lock the door.
Piggy Bank
08-21-2017, 11:18 AM
2018 33' Classic
Newport
, Pennsylvania
first if it is in freezing climate, winterize by pumping rv antifreeze thru all systems that have water in them.
drain all tanks
don't forget to bypass the water filter before winterization
wash
park inside a storage building out of the weather, take all the food out as it will draw mice
put "Cab Fresh" to keep the mice out...
I store mine in a " Earl Mumma perfect mouse protection" systems inside my Morton building!
I leave mine plugged into electric.
Good Luck
Earl
PS open all low point drains prior to filling water system with antifreeze, I then add rv antifreeze to the freshwater tank and pump it thru the demand pump, winterize the toilet and the inside and outside shower
Rv antifreeze in all sink and shower drains.
08-21-2017, 11:51 AM
2004 25' International CCD
Dubuque
, Iowa
Switching batts to Store isn't good enough for me. I disconnect Negative battery post
08-21-2017, 12:25 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
drain all tanks
wash
Good Luck
Earl
Or use an air compressor and fitting to blow out the lines of all the water.
Put anti-freeze into the 'P' traps of the sinks.
Use about 35 PSI or so. Do not exceed the system's pressure rating. (65?)
That's what CanAm does. It works.
08-21-2017, 06:57 PM
2019 30' Flying Cloud
Burlington
, Ontario
Good notes. We are into our 5th trip and I do all the things you have noted. Thanks.
08-23-2017, 05:18 AM
Sag Harbor
, New York
What kind of time span do you mean by "short term storage?"
Also your owner's manual has guidance on this, as well as on many other topics which should be studied before you use the trailer again.
"An ounce of prevention, . . . "
Cheers,
Peter
