Old 04-30-2015, 07:39 AM   #15
2015 30' International
FREDERICK , Maryland
Fill and drain times for fresh water tank
Just prepping for 2015 30' for the upcoming season. I know the fresh water tank is huge (54 gallons), but should it take 2 hours to drain? The trailer is level, I even left a faucet open, and the valve is open all the way but it is taking 2 hours to drain completely, which makes cleaning/sanitizing the tank a time consuming project.
Is this about normal?
It took me 17 minutes to fill. Maybe I am just too focused on time - oh well, used the time to silicone the window gaskets, check out all the awnings, prep the generators, etc.......
Doc Foster is offline   Reply With Quote
Old 04-30-2015, 07:58 AM   #16
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
How do you add the bleach? Do you pour it in the fresh water tank hole and let the water from the hose carry it through the system?
urnmor is offline   Reply With Quote
Old 04-30-2015, 08:18 AM   #17
chaseav's Avatar
2015 25' FB International
No other way to do it that I'm aware of. You should probably premix the bleach with some water (in a bucket or something) then dump it in.
chaseav is offline   Reply With Quote
Old 04-30-2015, 08:18 AM   #18
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
There's not much different you can do if sanitizing at the beginning of the season. I do it once or twice during the camping season. What I do is before leaving the last campsite to head for home I put the bleach solution into the fresh water tank through the filling tube. The tank would be partially filled by this time and on the way home it gets to slosh around thoroughly. Once home I open the drain and let it drain on the ground. It's just fresh water with a very diluted bleach solution so it won't do any harm.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-30-2015, 09:17 AM   #19
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
If you are draining using the tank's petcock valve it will take a long time. There should be another drain that uses the pump and is much faster. Not sure where the valve is located on your 2015 but probably near the hot water heater bypass. Look under your trailer to see where a piece of Pex tubing goes through the bellypan and the valve should be above that. When you locate it, turn on your water pump and open the valve to pump out the water.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 04-30-2015, 10:00 AM   #20
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Draining the fresh water tank using only the little petcock is a slow process. To speed things up, I usually turn the pump on and turn on the outside shower head cold water spigot and let it run out on the ground also.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 04-30-2015, 09:17 PM   #21
Msmoto's Avatar
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I do not think it takes my 54 gal tank 2 hours to drain. But, leave the filler tube cover open as this will allow air into the tank.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Sanitizing Fresh Water, Making a Bomb? HeadWest Fresh Water Systems 11 06-25-2013 12:07 PM
Sanitizing the water system zimbop Fresh Water Systems 13 02-11-2013 09:36 AM
Sanitizing Water System bike_addict LP Gas, Piping, Tanks & Regulators 27 10-12-2011 05:47 PM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 07:22 AM
Potable Water Tank Lee Pace Fresh Water Systems 4 09-01-2004 08:44 PM
