Old 10-04-2014, 06:10 PM   #1
Plays with old toys
pauluptime's Avatar
Toronto , Ontario
Rodents coming in through the fridge roof vent?
We're looking for where critters could be getting in and thinking the rooftop fridge vent might be an entry point?
In our case, it's chipmunks getting in to our '79 Sovereign. I'm going to have to do a real search and seal mission for small holes next weekend, but was thinking I may pull the fridge out and see if any evidence back there.
Since we don't run the fridge on propane, may I'll pack some aluminum wire mesh into the roof duct?
Paul
Team Uptime, ACT! Consultants in Toronto Canada
Photo album: New times with old toys
'79 Airstream Sovereign International '31
'75 Chevy Silverado Fleetside Pickup
'80 Baja 19TC "Twilight Cruiser" 260hp Speedboat
'65 Chevy Corvette Sting Ray Convertible
pauluptime is offline   Reply With Quote
Old 10-04-2014, 06:20 PM   #2
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
But really only when the chipmunk is not there! Or it already lives in the trailer?
I believe that the entry is from below, the animal slipped on the roof?!?
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 10-04-2014, 06:36 PM   #3
1981 31' Excella II
New Market , Alabama
There should be a heavy screen in the vent. They can get in from the rear bumper compartment and any other hole in the underbelly. There are usually gaps in the belly skin on these old trailers. Airstream did a poor job sealing floor penetrations. There are large gaps around sewer vents and under the furnace to name a few. Some have said they can get in through the slots in the step outriggers.
Perry
Old 10-04-2014, 07:42 PM   #4
Plays with old toys
pauluptime's Avatar
Toronto , Ontario
Perry
Thanks Perry. I'll check that the heavy vent screen is intact. I've plugged up the places you mentioned, but the step outriggers are one spot I forgot!
Paul
Old 10-04-2014, 08:03 PM   #5
1981 31' Excella II
There is a hotdog shaped dome over a stack. Inside the stack should be a screen or hardware cloth. The dome is riveted on but the rivets can be drilled out. Screws can be used to put the dome back on but you need to use caulk under them so they won't leak. This is a common place to run antenna wires through.
Perry
Wiring through the Fridge vent. HELP! Libo Generators & Solar Power 8 03-27-2013 07:07 AM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
Rodents in Tradewind lanajane General Repair Forum 2 06-27-2007 08:50 AM
Prevent rodents, ants in trailer. Ed Keyes 2001 Safari 3 09-12-2003 12:38 PM
How to keep rodents on the outside jtetzlaff General Repair Forum 2 01-06-2003 06:19 PM
