Old 06-23-2007, 07:41 AM   #1
2005 34' Classic
Richmond , Virginia
Quality covers
I dont know where to post this.
Does anyone know if there as a company that makes covers just for Airstreams. It will be a few years before I can store mine in a building and I cant stand to see it sit and bake in the sun all the time. Also i have a little antena for the radio on the front. Does that screw off so I can cover the unit.
Resorts is offline   Reply With Quote
Old 06-23-2007, 08:20 AM   #2
ScottW's Avatar
Hernando , Mississippi
Airstream advises NOT to cover the trailer. The cover will damage the clear coat (ie rub it off!). Not what you want to do.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-23-2007, 08:27 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Agreed. No covers for a newer Airstream.
Old 06-23-2007, 08:33 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Ditto, do not allow covers to touch the skin. I have a portable 'garage' canopy. The kind you put up for your extra cars. They come in all sizes. Mine is 10 X 30....a 10 X20 that I added to although I could have got the size I needed but I happen to have 2. I did have to add 16" legs to raise it so the AC would fit under. Down side is during the winter during snowfall (just a couple of times here) I go out, sometimes at night, and push the snow build up off by pushing a garage broom up from underneath. Wind is a problem too so secure it. For some extra bucks you can use a metal canopy.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-23-2007, 08:51 AM   #5
2005 34' Classic
Richmond , Virginia
Thanks for the info. I have a catalog for those canopies somewhere.
Old 06-23-2007, 09:22 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Hail
Originally Posted by anholman
I have a portable 'garage' canopy. The kind you put up for your extra cars. Neil and Lynn
My main worry here in New Mexico is hail damage. How do you think a canopy would hold up in a hail storm?
Old 06-23-2007, 09:52 AM   #7
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Agree with everything above...NO COVERS TOUCHING UNIT!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 06-23-2007, 12:04 PM   #8
Hawkeyes & Harleys
HOG-I's Avatar
2006 16' International CCD
Las Cruces , New Mexico
Marshall, I live in Las Cruces and about 5 years ago we had a nasty hail storm with hail no more than marble size. It still stripped every tree and did major dent damage to local cars etc. that were out side, also broke skylights (pretty heavy plastic). Any thing larger (golf ball size and above) and I would doubt that a cloth cover of any strength would hold. I bit the bullet and put in one of the aluminum car covers you see advertized everywher. Mine came from Roswell, and they assembled it on the spot. I sunk 2' deep by large coffee can size cement on the four corners prior to delivery for extra anchor. Big winds this spring were no problems (and we do have big winds down here). Also had to add 17" extensions to get the proper height and extra pannels to come down each side and the back for extra protection. 12'x20' ran a little over 1k set up. Hope this helps.
HOG-I is offline   Reply With Quote
Old 06-23-2007, 03:01 PM   #9
1973 23' Safari
Maryville , Tennessee
Images: 13
What about covers on a polished airstream with no clearcoat?
kneal is offline   Reply With Quote
Window Covers kzener40 Airstream Motorhome Forums 9 03-25-2012 05:27 AM
Vent Covers front two tmeagle1 Roof Vents, Skylights & Fans 1 05-15-2004 08:17 AM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
Tire covers Andy Fay Tires 1 11-16-2002 06:03 AM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
